It is currently Mon Mar 30, 2026 11:31 am
Reply to topic  [ 28 posts ]
 Winches
Post Winches
Can't figure out how to get to the old site... What kinda winches y'all using?
Tue Feb 17, 2009 10:59 am
Post Re: Winches
Warn 2.5 XT
Tue Feb 17, 2009 5:49 pm
Post Re: Winches
EVT Stage 1 32PD on a 17x48PD
"I'm not a Republican because I grew up rich. I'm a Republican because I did'nt want to spend the rest of my life poor. Waiting for the goverment to rescue me."
Mike Huckabee
Tue Feb 17, 2009 7:19 pm
Post Re: Winches
How are yall mounting them to the boat?
18X54 Center Console GTB/GTR35(lil daddy mods)
http://community.webshots.com/user/blaze715
Tue Feb 17, 2009 7:51 pm
Post Re: Winches
I mounted mine on my trolling motor bracket. It was the only place I knew I could mount it that had room for the winch to work and a thick surface. 2 quarter-twenty bolts and she is good to go.
Wed Feb 18, 2009 5:34 am
Post Re: Winches
Thinking of ordering this one...Yea or Na??????
http://www.gorillawinches.com/atv-winch ... ckage.html
Mon Mar 16, 2009 1:58 pm
Post Re: Winches
Coastal, that looks a lot like a warn... looks like they even use similar nomenclature... might be a good buy.
Mike Huckabee
Mon Mar 16, 2009 2:07 pm
Post Re: Winches
lot of the mudders over at highlifter.com use and like them.
Mon Mar 16, 2009 2:39 pm
Post Re: Winches
coastal glad you found that deal! i'm fixin to order me one also ordering a roller fairlead and wireless remote kit
if ya get a winch of any kind make sure you get the roller fairlead for it...the ones they come with even with syn. rope will mess the rope up
its under the "Winch Maintenance" button on that site
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Mon Mar 16, 2009 4:37 pm
Post Re: Winches
Just your basic cracka ass cracka
1840 gator tail with 35GTR
15xx Bateau with 15 honda
Mon Mar 16, 2009 7:38 pm
MMT Moderator
Post Re: Winches
I bought a Gorilla Winch it works well cheap too! Bought mine on Ebay came with a complete accessory kit and free shipping.
GTB 1860 w/ 2019 GTR40XD-HO
Fri Mar 20, 2009 6:34 pm
Post Re: Winches
I use a Superwinch 2000 that I picked up at Farm and Fleet for $69. Hooked a 18 inch chunk of chain with a hook, onto it so as to be able to hook it up anywhere on the hull depending on the circumstances.
Sun Mar 22, 2009 8:03 am
Post Re: Winches
Mitch,
How do you keep it out'a the water ???
Being movable sounds like a good trick....
Eat - Sleep - Hunt ! ! !
Sun Mar 22, 2009 11:14 am
MMT Moderator
Post Re: Winches
Mon Mar 23, 2009 2:20 pm
Post Re: Winches
you talkin bout quick connects on wires for the winch?
If so how do you have that rigged up...needin ideas on that part
Pete Willett
Mon Mar 23, 2009 2:32 pm
Post Re: Winches
Mon Mar 23, 2009 2:53 pm
Post Re: Winches
Willett, i have some borg warner part numbers for Oreillys... They are a 6 gauge quick disconnect and all you have to do is insert the wire, crimp it to the pin, and insert the pin into the plastic housing. Pretty easy.
Ill get it here in a little bit.
Mon Mar 23, 2009 3:02 pm
Post Re: Winches
good idea sand man
I kinda want some kind of plug that can be mounted flush with the deck (cables under deck) and just quickly plug in because like alot of folks my winch isnt gonna be mounted permanently to the boat...any ideas for that besides the one sanders showed in the link?
Pete Willett
Mon Mar 23, 2009 3:22 pm
Post Re: Winches
Add 6 gauge and your good to go. You can see some of those pins i was talking about in some of the picture. If you do order them, order 2. 1 box only has one connector.
Mon Mar 23, 2009 3:35 pm
Post Re: Winches
dynamite hooked you up. Pretty much the same connector warn uses.
Mon Mar 23, 2009 3:38 pm
Post Re: Winches
Yessir!
I think they are fairly inexpensive. Plus when you get all of the wire you need, you shall come up short of that warn kit.
So call up the local Tyler O'reillys on Front street and order up some plugs!
Mon Mar 23, 2009 3:43 pm
Post Re: Winches
FYI, if you run those leads all the way to the front of your boat, I would NOT leave them hooked to the battery. Don't ask why. I don't have time for another electrical lesson! :mrgreen: Just hook them up when you need power to your winch or put a solenoid in-line like warn uses with an on/off switch.
Mon Mar 23, 2009 3:46 pm
Post Re: Winches
thanks mitschke
and sanders thanks for the input...the winch came with the solenoid like comes with atv winches but still wouldnt leave it hooked up all the time...do they even make a switch that can hook up that large of wire?
Pete Willett
Mon Mar 23, 2009 9:11 pm
Post Re: Winches
You gonna have a TM up front so just use the the same plug for your winch. I use a short piece of chain and chain it to the bow or stearn eyes depending on what way I plan to winch the boat. Or just use a couple shackles. Plug it into the TM plug front or back. I have the TM plugs on my TM, winch and HH lights. You can make up a short line with a female plug on one end and clips on the other if you plan to use your winch elsewhere.
18x48 Charles Leonard / 36PD
Mon Mar 23, 2009 9:20 pm
Post Re: Winches
Mon Mar 23, 2009 9:24 pm
Post Re: Winches
yea was plannin on doing something to run everything off of...how large wire you run in that to power the winch
Pete Willett
Mon Mar 23, 2009 9:26 pm
Post Re: Winches
I think I used 8ga but my batteries are only a couple feet from the plugs front and back. If you gonna make a long run you probably need 6ga.
Mon Mar 23, 2009 9:32 pm
Post Re: Winches
yea thats what i was curious about connecting larger wire for a winch to a TM plug
Pete Willett
Mon Mar 23, 2009 9:38 pm
