ice man
New Member
 throttle handle mods on gtr35?
need advice- have very long runs, using gtr35 tiller handle, I find the stock throttle hard to hold for long periods. Can it be safely modified or is there a better aftermarket system?
| Wed Dec 02, 2009 10:13 am |
WestEndAngler
MMT Moderator
Joined: Thu Mar 05, 2009 9:11 am Posts: 9143 Location: Houston | Surfside
 Re: throttle handle mods on gtr35?
Hmmm good question.
I've seen many crawler rigs modified with bicycle gear changers to keep RPM's up while shifting or using clutch...
Why not retrofit a gear selector from a bicycle and tie into your throttle cable. You can set it with a few clicks and then when you want to back off just click it back down to the normal position.
I've seen this done when off roading just not done on the water. Could easily be adapted to work for the GTR or any rig for that matter.
_________________ GTB 1860 w/ 2019 GTR40XD-HO
| Wed Dec 02, 2009 11:09 am |
coondik
VELCRO!
| Wed Dec 02, 2009 11:26 am |
Tulsa_Woody
Joined: Wed Jan 14, 2009 8:31 am Posts: 428 Location: Tulsa, OK...Cajun by Marriage
I bought a four-wheeler thumb extension thingy at Wally-world...works pretty good.
I just took a dremel tool and trimmed off that bottom part. Woody
_________________ 17x54 Gator-Tail w/ 35HP GTR Gator-tail/MM exhaust Center Console...it fixes tiller torque viewtopic.php?f=4&t=9330
| Wed Dec 02, 2009 1:32 pm |
cypress
Joined: Mon Aug 17, 2009 8:28 pm Posts: 23 Location: Lafayette, LA
Woody,
I notice your power trim buttons on your grip. Do you have that with the new control box or the old?
Either way, what's the deal and the hook up?
| Wed Dec 02, 2009 4:32 pm |
slambin
Joined: Mon Feb 16, 2009 10:21 pm Posts: 1262 Location: St. Francisville, LA
I loosened mine and turned it down so that when im standing my hand just pulls against the throttle. I left it loose enough so that when it sit i just rotate it to make it comfortable to drive like that.
_________________ 2060 CC 3/4 Gator-tail 1/4 Brother Breaux Boat /35GTR Cowboy thought- a thong on a woman is like a barbed wire fence. It protects the property but doesnt obstruct the view.
| Wed Dec 02, 2009 4:38 pm |
Tulsa_Woody
cypress, i had a write-up on the GT forum but it is down...i'll give you a quick look with some pics...i basically bought a trim switch at academy and wired it in to the main trim switch.
Makes it possible to trim and reverse and throttle all at the same time!! Woody
| Thu Dec 03, 2009 9:48 am |
cypress
Got it. I have the new control box which contains the trim switch. It went out and the goodfellas at gt replaced it but i like your setup. One of the older boats in gt's yard had it as well. I suppose Kyle, et al will eventually redesign the setup to have the trim at your fingertips.
Thanks
Red Stripe...impressive.
| Thu Dec 03, 2009 11:37 pm |
muddiejeep
Joined: Tue Jan 13, 2009 6:24 pm Posts: 761 Location: New Orleans, LA.
_________________ When in doubt, throttle out. 18x60 prodrive w/36 prodrive
| Fri Dec 04, 2009 7:54 pm |
