It is currently Wed Apr 08, 2026 2:15 am
Reply to topic  [ 20 posts ]
 Need Some Help
Post Need Some Help
I know this doesn't pertain to mudboats but i have a 14 foot 1975 cajun hull with a 25 evinrude and at full throttle the front end diggs horribily....does anybody have any advice or tips :?:
Mon Mar 15, 2010 6:29 pm
Post Re: Need Some Help
Adjust your trim?
Mon Mar 15, 2010 6:31 pm
Tried adjusting it it still doesn't help...i have the gas tank in the back and batteries!
48x16 custom wood hull wt 25 onan performer
Mon Mar 15, 2010 6:34 pm
The hull isn't warped is it? Sounds kinda weird. I would think it would somehow have to be trim related. Is this a new package for you? It's done this as long as you've owned it?
Mon Mar 15, 2010 6:36 pm
i had the motor on a 14ft lowe line hull and it did the same thing so i sold the lowe hull and picked this one up..the hull is warped or bend and i caint figure out y it is digging...could it possibily be the prop?
Mon Mar 15, 2010 6:41 pm
it isnt bent**
Mon Mar 15, 2010 6:42 pm
Maybe, it would have to be way outta whack though. The transom angle couldn't be that far off on two different boats, ya think? I dunno man. Maybe one of these boys with a lil more experience will chime in here before too long. I went over the obvious.
Mon Mar 15, 2010 6:51 pm
Location: In a trailer of common sense, looking out the window at a tornado of stupidity
you probably have, but I have to ask --
Have you adjusted the transom angle adjustment rod?
It sets the angle of the motor against your transom - it's a pin right at the pivot point of the motor.
Mon Mar 15, 2010 6:53 pm
yea idk what to do with it...thanks for the replys though
Do you have a long shaft motor on a short transom boat?
Mon Mar 15, 2010 6:54 pm
If the Steel aint Flying the Birds aint Dying....
Uncle J 1948 holding a LT
Uncle J 1848 w/?
Mon Mar 15, 2010 6:56 pm
I havent adjusted the pin because i didnt kno it was there..im a newbie with outboards...no it is the rite transom for the motor
Mon Mar 15, 2010 6:57 pm
Mon Mar 15, 2010 6:59 pm
Thats what I was meaning by adjusting the trim, I just didn't say it right, I guess. Oh well. That should fix the problem.
Mon Mar 15, 2010 7:06 pm
Mon Mar 15, 2010 7:15 pm
Put a straight edge on the bottom of boat from transom forward, sounds like you have hook in the hull. If you see alot of daylite between edge and hull this could cause your problem. Not much you can do for it.
Tue Mar 16, 2010 8:14 am
Tue Mar 16, 2010 7:58 pm
well guys i think i found the problem the caviation plate was bent down rite behind the transome so im thinkin that this was y it was dragging..gunna go put it in the water tom and see what happens
Tue Mar 16, 2010 9:01 pm
Let us know how it turns out. Good luck
Tue Mar 16, 2010 9:10 pm
i went run the boat today and that must have been the problem cuz she runs like a pro now so thanks for all the help guys :)
Wed Mar 17, 2010 7:20 pm
