It is currently Wed Dec 24, 2025 11:55 pm
Reply to topic  [ 5 posts ]
 HELP!!
Post HELP!!
Gator-tail is closed today and my power trim broke today on my gator-tail and need it tomorow. my relay is clicking when i hit my switch that fuse like a 25amp i believe is still good i'm hoping the trim unit itsself isn't burnt up does anyone know what else i could check??
Sat Mar 21, 2009 5:23 pm
Post Re: HELP!!
Hit the braker reset buton. Also if you run in salt water check every connection for corrosion. Next pull the relays and switch them around.
Sat Mar 21, 2009 6:00 pm
Post Re: HELP!!
thanks i ended up finding the problem it was the connector where the blue and green wires connect to the white and black, butt spliced them together for now and good to go.
Sat Mar 21, 2009 6:51 pm
Post Re: HELP!!
cool :D
Sat Mar 21, 2009 8:21 pm
Post Re: HELP!!
jb if that ever happens again ... put the blue wire on positive side of battery and that will make it go up if want it to go down put the green wire on positive....
boatless!!!!!!!!!
Sun Mar 22, 2009 12:04 pm
