| Tiny Tach http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=11806 |
| Author: | cmiller73 [ Fri Aug 20, 2010 4:24 pm ] |
| Post subject: | Tiny Tach |
I did a search but there is nothing specific about what I am trying to find out. So I bought one today. The "Gas" Version. The model I have is the one where you change the settings for spark. Could this be set wrong? Doesn't a gas engine have a spark every other rev? 1 for combustion 1 for ingnition. That means it would be set on 720 not 360 right? I'm stumped. |
| Author: | kibb [ Fri Aug 20, 2010 5:52 pm ] |
| Post subject: | Re: Tiny Tach |
Intake, compression, combustion (power), exhaust. Single cylinder fires every other revolution. V-twin fires every revolution opposite cylinder each time. As for the setting, I'm not sure. |
| Author: | cmiller73 [ Fri Aug 20, 2010 6:08 pm ] |
Woops said the wrong thing. Should it be set at 180 instead of 360? Maybe it's right, but 5k rpms sounds a bit high. Thanks for the help Kibb |
| Author: | caddobrook [ Fri Aug 20, 2010 6:45 pm ] |
doubt if that is right. think there is a setting for number of cylinders and you probably need to adjust that... |
| Author: | cmiller73 [ Mon Sep 13, 2010 8:55 am ] |
Still having issues with this tiny tach. If I set it up to read the idle RPMs right, which are 1000-1100 RPM, at WoT out of the water, I only get 2300-2400 RPMs. MAx for this 6.5 is 3850+/-150 RPM. According to this page, it is to be set at 720, but then the RPM at idle is 2400ish. Right now I have is set at 180 and the idle speed is right, but this setup is for 2 sparks per revolution. Doesn't make any sense. http://www.tinytach.com/tinytach/pdf/TT ... ctions.pdf |
| Author: | cmiller73 [ Fri Sep 17, 2010 5:16 pm ] |
OK, talked with the Tiny Tach tech and he said add more wraps and I did. Here is what I have. What do I have wrong? |
| Author: | Flyn IT's Dien [ Sat Sep 18, 2010 10:33 am ] |
wrap it around the ceramic part on the spark plug... |
| Author: | cmiller73 [ Sat Sep 18, 2010 1:59 pm ] |
| Author: | Flyn IT's Dien [ Sat Sep 18, 2010 2:11 pm ] |
| Author: | cmiller73 [ Sun Sep 19, 2010 8:36 am ] |
| Author: | kibb [ Sun Sep 19, 2010 4:41 pm ] |
Its in the correct place. |
| Author: | Flyn IT's Dien [ Sun Sep 19, 2010 7:48 pm ] |
cMiller73, when i bought the MM it was wraped around the ceramic part of the SP. I asked my buddy who works at a mower shop and he said its fine where its at... idk it might be in the worng place. ima call setx tmro and see what they have to say. |
| Author: | GeeLeDouche [ Tue Sep 21, 2010 1:16 am ] |
I just wrapped mine around one of my plug wires like you have done and it works great. |
| Author: | cmiller73 [ Tue Sep 21, 2010 7:35 am ] |
