It is currently Thu Jul 30, 2026 12:27 pm
Reply to topic  [ 14 posts ]
 Tiny Tach
Post Tiny Tach
I did a search but there is nothing specific about what I am trying to find out.
So I bought one today. The "Gas" Version. :roll: Well, I installed it according to the directions, cranked the motor up, hit the throttle and had a Max RPM of 5000. :o This little motor is supposed to have max RPM of 3600. It also says it's idle is 2300. These numbers sound high. Don't they?
The model I have is the one where you change the settings for spark. Could this be set wrong? Doesn't a gas engine have a spark every other rev? 1 for combustion 1 for ingnition. That means it would be set on 720 not 360 right?
I'm stumped.
Copperhead 12Hp SD on 1442 Alweld
Fri Aug 20, 2010 4:24 pm
Post Re: Tiny Tach
Intake, compression, combustion (power), exhaust. Single cylinder fires every other revolution. V-twin fires every revolution opposite cylinder each time. As for the setting, I'm not sure.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Fri Aug 20, 2010 5:52 pm
Post Re: Tiny Tach
Woops said the wrong thing. Should it be set at 180 instead of 360?
Maybe it's right, but 5k rpms sounds a bit high.
Thanks for the help Kibb
Fri Aug 20, 2010 6:08 pm
Post Re: Tiny Tach
doubt if that is right. think there is a setting for number of cylinders and you probably need to adjust that...
Fri Aug 20, 2010 6:45 pm
Post Re: Tiny Tach
Still having issues with this tiny tach. If I set it up to read the idle RPMs right, which are 1000-1100 RPM, at WoT out of the water, I only get 2300-2400 RPMs. MAx for this 6.5 is 3850+/-150 RPM.
According to this page, it is to be set at 720, but then the RPM at idle is 2400ish. Right now I have is set at 180 and the idle speed is right, but this setup is for 2 sparks per revolution.
Doesn't make any sense.
http://www.tinytach.com/tinytach/pdf/TT ... ctions.pdf
Mon Sep 13, 2010 8:55 am
Post Re: Tiny Tach
OK, talked with the Tiny Tach tech and he said add more wraps and I did. Here is what I have. What do I have wrong?
Fri Sep 17, 2010 5:16 pm
Post Re: Tiny Tach
wrap it around the ceramic part on the spark plug... :)
"A duck for a fuc* a fuc* for a duck and 25 bucks for a fuc*ed up duck"
Sat Sep 18, 2010 10:33 am
Post Re: Tiny Tach
Sat Sep 18, 2010 1:59 pm
Post Re: Tiny Tach
Sat Sep 18, 2010 2:11 pm
Post Re: Tiny Tach
Sun Sep 19, 2010 8:36 am
Post Re: Tiny Tach
Its in the correct place.
Sun Sep 19, 2010 4:41 pm
Post Re: Tiny Tach
cMiller73, when i bought the MM it was wraped around the ceramic part of the SP. I asked my buddy who works at a mower shop and he said its fine where its at... idk it might be in the worng place. ima call setx tmro and see what they have to say.
Sun Sep 19, 2010 7:48 pm
Post Re: Tiny Tach
I just wrapped mine around one of my plug wires like you have done and it works great.
Tue Sep 21, 2010 1:16 am
Post Re: Tiny Tach
Tue Sep 21, 2010 7:35 am
