| ProDrive traveling question http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=12553 |
| Author: | clidwin [ Tue Sep 21, 2010 2:42 pm ] |
| Post subject: | ProDrive traveling question |
When you are traveling with your prodrive do you have it in the reverse position? or you strap it down? what do you do. Thanks |
| Author: | cb5331 [ Tue Sep 21, 2010 2:45 pm ] |
| Post subject: | Re: ProDrive traveling question |
Trim it all the way up, and tie the handle off so it don't swing back and fourth. Some don't even go that far, but that's what I do. |
| Author: | bpurvis [ Wed Sep 22, 2010 5:33 pm ] |
yep I have a 32Pd and i just tighten my tension bar all the way down, trim the motor all the way up and shove the tiller handle to one side and roll that B**ch down the boad |
| Author: | Bream Busta [ Wed Sep 22, 2010 7:16 pm ] |
yap, da best way ive found is trim it, wrap a rubber bungee strap around ur tiller handle and strap it to da back of ur boat. u should never have any problems if u do this. |
| Author: | mudder [ Thu Sep 23, 2010 2:03 pm ] |
| Author: | OwenDickeson [ Thu Sep 23, 2010 2:30 pm ] |
I wouldn't tighten down the tension knob to secure the motor to one side. You will just wear out the teflon bushing prematurely. |
| Author: | OwenDickeson [ Thu Sep 23, 2010 2:33 pm ] |
You can cut a block of wood to keep it from moving from side to side like I did. Or use a bungee cord. |
| Author: | mudman350 [ Thu Sep 23, 2010 2:59 pm ] |
however it goes on the trailer is how i haul it haha |
| Author: | dpd [ Fri Sep 24, 2010 7:01 pm ] |
I just trim it up and go. |
| Author: | BradS [ Sat Sep 25, 2010 5:42 am ] |
If you have the hyd trim DO NOT travel with the motor trimmed all the way up. You will bust your hoses Trim all the way up then trim down just enough to relieve the pressure and the motor moves a little bit, I put the reverse lock on and bungee cord the tiller to the grab handle on the back of the boat, |
