It is currently Tue Jul 28, 2026 11:48 pm
Reply to topic  [ 10 posts ]
 ProDrive traveling question
Post ProDrive traveling question
When you are traveling with your prodrive do you have it in the reverse position? or you strap it down? what do you do. Thanks
Tue Sep 21, 2010 2:42 pm
Post Re: ProDrive traveling question
Trim it all the way up, and tie the handle off so it don't swing back and fourth. Some don't even go that far, but that's what I do.
Tue Sep 21, 2010 2:45 pm
yep I have a 32Pd and i just tighten my tension bar all the way down, trim the motor all the way up and shove the tiller handle to one side and roll that B**ch down the boad :D
Sold my Uncle-J and my PD so Fuc* Y'all!!!!!.
"THE EDGE: There is no honest way to explain it because, the only ones who know where it is have gone over. The others... the living, are those who've pushed their control as far as they felt they could handle and then pulled back or slowed down........BUT the edge is still out there...."
Wed Sep 22, 2010 5:33 pm
yap, da best way ive found is trim it, wrap a rubber bungee strap around ur tiller handle and strap it to da back of ur boat. u should never have any problems if u do this.
1850 Custom Flat wit a lil B&B Fab followed by a 36 Prodrive FPR
Wed Sep 22, 2010 7:16 pm
Thu Sep 23, 2010 2:03 pm
I wouldn't tighten down the tension knob to secure the motor to one side. You will just wear out the teflon bushing prematurely.
Thu Sep 23, 2010 2:30 pm
You can cut a block of wood to keep it from moving from side to side like I did. Or use a bungee cord.
Thu Sep 23, 2010 2:33 pm
however it goes on the trailer is how i haul it haha
36hp pro-drive pushin a 1748 rick aucoin skiff
1500hp Mitsubishi pushing a 50' push boat
200merc pushing a 20' Mako
Thu Sep 23, 2010 2:59 pm
I just trim it up and go.
Fri Sep 24, 2010 7:01 pm
If you have the hyd trim DO NOT travel with the motor trimmed all the way up. You will bust your hoses
Trim all the way up then trim down just enough to relieve the pressure and the motor moves a little bit, I put the reverse lock on and bungee cord the tiller to the grab handle on the back of the boat,
Sat Sep 25, 2010 5:42 am
