It is currently Sat Jul 05, 2025 12:46 am
Reply to topic  [ 19 posts ]
 Question on new Gator-tail
Post Question on new Gator-tail
Just got a 2011 gator tail 35 & gator tail boat & ran it the other day,this motor is loud! but it's not coming from the exhust, stock. It's sounds like a loud fan.I had a 06 mb 35 & the motor didn't sound like this. Is this normal for these new motors? Help appreciated.
Tue Oct 19, 2010 6:51 pm
Post Re: Question on new Gator-tail
Spin your air filter cover around.
Tue Oct 19, 2010 7:28 pm
Tried it and it didn't help.Anything over 3000 rps and I'am looking for ear plugs.
Tue Oct 19, 2010 7:39 pm
Sound crazy call gt first thing !!
17x48 extreme stage 2 GTR
Tue Oct 19, 2010 7:41 pm
Called gator tail and they said it shouldn't be like that and will call me back.
Tue Oct 19, 2010 7:47 pm
Brought boat back to gt for a ride & they said the noise is normal. Great guys at gt. They said it might be the prop which checked out good. I will try a friends mb prop to see if it helps. I love the boat & the performance of this rig,but I hope I can get the noise down.
Thu Oct 21, 2010 8:12 pm
Some might say just put a loud exhaust on it and then you are good to go ! ! !
Just joking.... Any chance there could be some vibration noise from the
hull or under the floor... I know of a truck built before a strike where there
were like 3 or 4 bolts dropped into the doors with tags attached that said
"you finally found me" --- any way they made a heck of a noise on rough
roads and almost none on others.... A bit of debris like a few rocks might
have gotten in there....
Good Luck - hope you have lots of enjoyment with your rig...
Eat - Sleep - Hunt ! ! !
Thu Oct 21, 2010 8:44 pm
G, you cannot even hear the over exhust 32000 rpm's.
Thu Oct 21, 2010 8:55 pm
Thu Oct 21, 2010 9:01 pm
When the motor is in gear out the water it sounds normal,but when you put a load on it in the water over 3000 rpm's it loud but not form the exhust,I ran it the other day & after 15 minuts I was looking for ear plugs. I have been running a 35 hp sd motor for over 3 years and this motor is much louder,and when you run a few hours a day hunting & and fishing it might get rough.
Thu Oct 21, 2010 9:31 pm
Sounds like you need to take it back to Gator-Tail and tell them to fix it.
Fri Oct 22, 2010 8:37 pm
Just bought mine thursday and took it out today for the first time. I thought the same thing, damn it's loud after 3,000 rpms.
When I got home I started checking and found that the plastic clutch cover has some rattles. I took it off by removing the 2 side bolts and worked it off. you can see by the black dust where it's been rubbing.
I have a roll of 1/8" x 2" insulation tape that I cut and stuck on the spots where it rattles (under side bolts and where the clutch base touches the cover).
Now you can slap it around and hear nothing. will try it out tomorrow.
Even the ignorant can appear intelligent....... if I keep my mouth shut.
Sat Oct 23, 2010 6:24 pm
I ran a old 11"mb prop I had the other day and it was a little better but not by much.I did check for loose covers and parts but every thing was tight. It must be the belt when it is put under a load, which is a new style.
Tue Oct 26, 2010 6:46 pm
It's your prop hitting the water.
"You may all go to hell, as for me I'm going to Texas" D. Crockett
What is best in life?
To crush your enemies, to see them driven before you, and to hear the lamentations of their women.
Thu Oct 28, 2010 10:41 am
Thu Oct 28, 2010 12:34 pm
No, the boat is faster with the prop out the water.
Thu Oct 28, 2010 1:02 pm
Thu Oct 28, 2010 1:25 pm
Try trimming down just a little bit.It sounds to me like you have to much prop out of the water.
1750GATOR TRAX &MB4000&MPE
Thu Nov 04, 2010 6:33 am
Thu Nov 04, 2010 8:13 am
Users browsing this forum: Google [Bot] and 151 guests
