It is currently Mon Jul 07, 2025 10:11 am
Reply to topic  [ 9 posts ]
 Prodrive question...
Post Prodrive question...
my motor just started running a little wierd this past sunday while out hunting. its like its not running to its full potential. it'll only turn about 3650-3700 rpms, and i can tell its lost quite a bit of speed. i changed the spark plugs yesterday and when i pulled them out, one was wet (damp) and the other was completely dry. i dont know if this has anything to do with it. im for sure not a damn mechanic. i dont think it could be the prop being as the motor is a little over a year old and it hasnt been through to much nasty stuff. just looking for some advice on whats going on here guys. it is a 36hp with the new marine edition PD.
Wed Nov 03, 2010 10:43 pm
Post Re: Prodrive question...
Side that is wet could not be firing all the time
Thu Nov 04, 2010 8:56 am
Thu Nov 04, 2010 1:52 pm
how do i check this?
Thu Nov 04, 2010 2:19 pm
you can check to see if a plug is firing by taking it out and reconecting the wire to the plug. Then ground the plug to a metal part on the motor and turn the motor on. warning hold onto the rubber part cause it will give you a little shock if not.
17*38 Klibert 23GDLT
Thu Nov 04, 2010 2:31 pm
When you get that solved, make sure your neutral rpms are set at 4300
Thu Nov 04, 2010 5:36 pm
i checked what both of yall said today, i definatley got the spark from the plug lol, and i was only gettin 4150 rpms neutral.
Thu Nov 04, 2010 10:38 pm
sounds kinda weird but get a gauge and check your compression psi on each cylinder
Fri Nov 05, 2010 11:51 am
Fri Nov 05, 2010 4:28 pm
Users browsing this forum: No registered users and 84 guests
