Prodrive question... http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=13530 |
Author: | hunterg [ Wed Nov 03, 2010 10:43 pm ] |
Post subject: | Prodrive question... |
my motor just started running a little wierd this past sunday while out hunting. its like its not running to its full potential. it'll only turn about 3650-3700 rpms, and i can tell its lost quite a bit of speed. i changed the spark plugs yesterday and when i pulled them out, one was wet (damp) and the other was completely dry. i dont know if this has anything to do with it. im for sure not a damn mechanic. i dont think it could be the prop being as the motor is a little over a year old and it hasnt been through to much nasty stuff. just looking for some advice on whats going on here guys. it is a 36hp with the new marine edition PD. |
Author: | take'emgator [ Thu Nov 04, 2010 8:56 am ] |
Post subject: | Re: Prodrive question... |
Side that is wet could not be firing all the time |
Author: | postalpaul [ Thu Nov 04, 2010 1:52 pm ] |
Author: | hunterg [ Thu Nov 04, 2010 2:19 pm ] |
how do i check this? |
Author: | da go get'er [ Thu Nov 04, 2010 2:31 pm ] |
you can check to see if a plug is firing by taking it out and reconecting the wire to the plug. Then ground the plug to a metal part on the motor and turn the motor on. warning hold onto the rubber part cause it will give you a little shock if not. |
Author: | OwenDickeson [ Thu Nov 04, 2010 5:36 pm ] |
When you get that solved, make sure your neutral rpms are set at 4300 |
Author: | hunterg [ Thu Nov 04, 2010 10:38 pm ] |
i checked what both of yall said today, i definatley got the spark from the plug lol, and i was only gettin 4150 rpms neutral. |
Author: | postalpaul [ Fri Nov 05, 2010 11:51 am ] |
sounds kinda weird but get a gauge and check your compression psi on each cylinder |
Author: | OwenDickeson [ Fri Nov 05, 2010 4:28 pm ] |
