It is currently Fri Jul 11, 2025 8:28 pm
[ 9 posts ] |
hunterg
Joined: Tue Sep 29, 2009 10:21 pm Posts: 188 Location: SETX
 Prodrive question...
my motor just started running a little wierd this past sunday while out hunting. its like its not running to its full potential. it'll only turn about 3650-3700 rpms, and i can tell its lost quite a bit of speed. i changed the spark plugs yesterday and when i pulled them out, one was wet (damp) and the other was completely dry. i dont know if this has anything to do with it. im for sure not a damn mechanic. i dont think it could be the prop being as the motor is a little over a year old and it hasnt been through to much nasty stuff. just looking for some advice on whats going on here guys. it is a 36hp with the new marine edition PD.
Wed Nov 03, 2010 10:43 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
 Re: Prodrive question...
Side that is wet could not be firing all the time
Thu Nov 04, 2010 8:56 am |
postalpaul
Joined: Sun Nov 01, 2009 6:25 pm Posts: 1935 Location: Kaufman- TEXAS
Thu Nov 04, 2010 1:52 pm |
hunterg
how do i check this?
Thu Nov 04, 2010 2:19 pm |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
you can check to see if a plug is firing by taking it out and reconecting the wire to the plug. Then ground the plug to a metal part on the motor and turn the motor on. warning hold onto the rubber part cause it will give you a little shock if not.
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
Thu Nov 04, 2010 2:31 pm |
OwenDickeson
When you get that solved, make sure your neutral rpms are set at 4300
Thu Nov 04, 2010 5:36 pm |
hunterg
i checked what both of yall said today, i definatley got the spark from the plug lol, and i was only gettin 4150 rpms neutral.
Thu Nov 04, 2010 10:38 pm |
postalpaul
sounds kinda weird but get a gauge and check your compression psi on each cylinder
Fri Nov 05, 2010 11:51 am |
OwenDickeson
Fri Nov 05, 2010 4:28 pm |
[ 9 posts ] |
Users browsing this forum: No registered users and 95 guests |
