| Rewiring GD Boat http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=1478 |
| Author: | lagunaduck [ Fri Apr 10, 2009 4:05 pm ] |
| Post subject: | Rewiring GD Boat |
Old GD boat wiring is getting brittle. I had to make a couple splices during last season and would like to replace the wiring. What gauge wiring do I need and how much? Any advice on this job? |
| Author: | Mudgun [ Fri Apr 10, 2009 5:00 pm ] |
| Post subject: | Re: Rewiring GD Boat |
Scotchkote everything! |
| Author: | deadbird8 [ Fri Apr 10, 2009 5:23 pm ] |
Depends on the runs/where your battery is/what you run in the boat. 100W spots draw 8.3Amps, bilge pump- 2-4, running lights 1-2. If you control high amp stuff from a switch in the back, you may want to look at installing a relay. Cover your connections with liquid electrical tape, if you add a piece of shrinkwrap over it you get a clean looking connection. Check Mudd's site for spot wiring, may give you some ideas: |
| Author: | lagunaduck [ Sat Apr 11, 2009 8:18 pm ] |
Thanks for all the info. I don't have much accessories. I use a hand held spot light or hard hat light. So all I really have are the running lights. |
