It is currently Sat Apr 04, 2026 12:25 pm
[ 5 posts ] |
scotty
Joined: Sun Feb 01, 2009 8:44 am Posts: 61 Location: Port O'Connor Tx / Seguin Tx
 Bending skeg ??
The tiller handle really pulls to the right. Should I bend the skeg to the left if looking at it from behind? Also, there is something screwed to the skeg as shown in the the pic. Do I take that off and move it or just bend the skeg with that in same spot. How much do you bend the skeg??
| Mon Apr 13, 2009 11:26 am |
Crews
Joined: Wed Jan 14, 2009 9:07 pm Posts: 2260 Location: Lafayette
 Re: Bending skeg ??
not sure about your type of motor, but you sure you just don't have it trimmed up too high or something simple like that?
_________________ 24x60 Dual Prodrives
| Mon Apr 13, 2009 11:42 am |
PaulDarensbourg
Joined: Fri Jan 23, 2009 11:07 am Posts: 602 Location: Baton Rouge
 Re: Bending skeg ??
I can't see the pic, but I am sure you are talking about the torque tab that GT puts on the skeg plate. Mine fell off pretty quick, really don't understand why they don't weld those on. I bent mine and it made a world of difference. You can leave the tab on or take it off. I would just go ahead and take it off and throw it away then bend the plate.
| Mon Apr 13, 2009 12:01 pm |
Tulsa_Woody
Joined: Wed Jan 14, 2009 8:31 am Posts: 428 Location: Tulsa, OK...Cajun by Marriage
 Re: Bending skeg ??
scotty, before you go bending the skeg, move your weight around...try to balance it out, because i can make mine push or pull me just by moving someone from one side to the other. Woody
_________________ 17x54 Gator-Tail w/ 35HP GTR Gator-tail/MM exhaust Center Console...it fixes tiller torque viewtopic.php?f=4&t=9330
| Mon Apr 13, 2009 12:28 pm |
huntfishrace
Joined: Thu Mar 12, 2009 5:28 pm Posts: 63 Location: central La.
 Re: Bending skeg ??
my GTR pulled a little but not bad so bent it some more and it worked great. Went from a six gal. to an eight gal. and changed sides of boat and motor started to pull again. Had to straighten it back out so play with weight and bending to fine tune your motor. worked for me
_________________ 1546 Triton with 35 GTR
| Mon Apr 13, 2009 4:22 pm |
[ 5 posts ] |
