It is currently Mon Mar 30, 2026 8:38 am
Reply to topic  [ 14 posts ]
 Paint application Question
Post Paint application Question
Can anyone tell me why my paint lays on looking dusty and shows the beginning and end of each pass. I am using a Harbor Freight gravity feed. I am applying Duralux flat boat green and thinning with Xylene. I am needing to thin the paint more that stated in the instructions cause paint is still to thick for the gun. Does thinning to much cause this, not thinning enough? Is it just a shitty paint? I tried adjusting the air, but it seems to get worse.
Mon Apr 06, 2009 9:12 pm
Post Re: Paint application Question
Sounds like you are thining it to much
Pro Drive m'fers
Mon Apr 06, 2009 9:29 pm
paul how old is the paint? pooh bear had problems with sum duralux of his last month when he was doin another boat.. same thing, w/ the harbor freight gun. the paint layed down fine on my boat ( i had the ace paint) but the duralux didnt go thru the gun well at all. we think it could have been settin up for a while.
Mon Apr 06, 2009 9:34 pm
Profile YIM WWW
you need to adjust the air to paint mix. Sounds like the paint is drying before it hits the boat.
Mon Apr 06, 2009 9:41 pm
or spraying from to far away?
Tue Apr 07, 2009 5:35 am
Try using a air sprayer. That should take care of your problem.
Tue Apr 07, 2009 6:06 am
Paint is brand new, I spray it from about 8 inches away, but the idea about it drying before it gets to the surface is what it is doing. I think I am just gonna try a different kind of paint. Could it be drying fast from being thinned out to much?
Tue Apr 07, 2009 2:31 pm
Tue Apr 07, 2009 2:38 pm
I know. I was having the same problem. It took me just a little while before I figured out what to do. I let my brother-in-law paint it.
Wed Apr 08, 2009 5:55 pm
M-E-T-R-O-S-E-X-U-A-L-S shouldn't be painting anything but der fingernails!!!!!!!!!!!!!
Wed Apr 08, 2009 7:11 pm
Wed Apr 08, 2009 9:06 pm
Thu Apr 09, 2009 6:17 am
Thu Apr 09, 2009 7:35 am
Sounds to me like a number of things are working against each other. I'm not familiar with the harbor fright gun that ur using but seems like ur cap pressure is way off. So what pressure r u spraying at? Also seems like the paint volume adjustment. Is. To little. Anotherwards not enough paint comming out of the gun compared to the pressure that is comming out at the cap. So do u have a knob that adjust the volume.
Also what is the ratio that u r mixing with the paint? Answer my questions and ill tell u ur problem
Tue Apr 14, 2009 3:38 pm
