It is currently Sat Mar 28, 2026 12:15 pm
Reply to topic  [ 25 posts ]
 Make the engine surface?
Post Make the engine surface?
What would want to make the prop come out of the water? I have a 35 GDSD with 90 hrs. has some prop wear but nothing drastic. I've bent my trim tabs and it wants to run about half the prop out of the water. I heard on longtails it's a worn prop. I have to pull up on the handle to get it to run right.
Freedom It Wasn't Free!!!
It Was Won!!!
Enjoy It!!!
The more you try to teach a stupid person something the dumber you get!!!
Tue Apr 14, 2009 8:04 pm
Post Re: Make the engine surface?
what way did you bend the two tabs? did it run right for the 90 hours?
Tue Apr 14, 2009 8:17 pm
Bent the trim tabs up toward the cav. plate. It hops out the water about 100 yds. into a run then it seems to go to the same spot. Even trimmed it down below normal and goes back.
It Was Won!!!
Enjoy It!!!
Tue Apr 14, 2009 8:20 pm
Has this always happen? Any changes to the original set-up? What type of boat are you running?
Tue Apr 14, 2009 8:24 pm
Well I bought the engine used and it has done it from the day I bought it. I'm running an xpress 1650 Duck boat. This never happened when I had the 27 on it. Kinda got me stumpped.
It Was Won!!!
Enjoy It!!!
Tue Apr 14, 2009 8:27 pm
La
The 35 GDSD is very neutrally balanced - when the prop has about 1/4 inch of wear it will do what you are describing - where you have to lift the handle to keep it in the proper trim position - new prop time...
Tue Apr 14, 2009 8:32 pm
New prop or get cup added?
It Was Won!!!
Enjoy It!!!
Tue Apr 14, 2009 8:35 pm
Take it to Baggy's prop shop in Houma. He can fix you up.
Tue Apr 14, 2009 8:38 pm
La,
The 27 was about 20 pounds tail heavy - 35 is not....
Prop wear is deceptive - if you measure the blade width at half way
down to the tips - that is where most "sand wear" occurs.....
New prop....
Just went through this debate with my buddy - night and day difference
now with the new prop on....
Tue Apr 14, 2009 8:39 pm
Without seeing the tabs, my 1st suggestion would be bend the tabs more. Go to an area where you can run the boat. Bring a adjustable wrench or very large channel locks, try the boat. If the condition still persist pull over and bend the tabs a little more. Keep this process until motor rides on the trim. I have set three GDSD and each one was a little different. Warren told me that the motor should ride on the trim, so when it is adjusted correctly you should be able to slow the RPM'S by trimming the motor down, the motor should be on the trim. This should take care of your problem, just a little trial and error. Good luck
Tue Apr 14, 2009 8:40 pm
Ain't quite sure how to measure a 3 blade, but Donna @ Go Devil said to the widest point. I measured mie with a blde top center to the tip of the blade to the right and got 10"
It Was Won!!!
Enjoy It!!!
Tue Apr 14, 2009 8:43 pm
It Was Won!!!
Enjoy It!!!
Tue Apr 14, 2009 8:47 pm
if the motor has alway done this since you purchased it, I really think it just needs to be adjusted. Call Warren at GoDevil and see what he suggest before you start spending money.
Tue Apr 14, 2009 8:49 pm
Tue Apr 14, 2009 8:51 pm
It Was Won!!!
Enjoy It!!!
Tue Apr 14, 2009 8:54 pm
It Was Won!!!
Enjoy It!!!
Tue Apr 14, 2009 8:55 pm
La,
Take your old prop and measure against a new one....
Bet you will find that you have more wear than you thought,
especially at mid blade where you least expect it - half way from
the hub out to the blade tip - I think that is what causes the
prop lift you are having..... No clue if just cup would help ?
Only way I could convince my buddy was a mid day prop swap
where he put my new 3 blader on - and I put his worn one on....
Night and day difference....
Tue Apr 14, 2009 8:58 pm
On your surface drive more cup will normally cause the prop to rise in the water not bite more. Do not be scared to bend those two tabs. They are what controls the prop height. When the prop floats like you are describing, bend the tabs a little more and you should have it. Nice speeds!!
Tue Apr 14, 2009 9:01 pm
Will bend tabs and rerun the boat. When I beat brother in law I had 100 lbs more than him in the boat too.
It Was Won!!!
Enjoy It!!!
Tue Apr 14, 2009 9:03 pm
Just your basic cracka ass cracka
1840 gator tail with 35GTR
15xx Bateau with 15 honda
Tue Apr 14, 2009 10:12 pm
It Was Won!!!
Enjoy It!!!
Tue Apr 14, 2009 10:25 pm
I don't know about the GDSD but the GT your supposed to run with half the prop out the water for maximum performance.
Wed Apr 15, 2009 5:59 am
your motor should not be floating, it should ride on the trim. This will help you when you are running in vegataion. You should not have to stand and hold pressue upward unless you are running lillies. If your motor is floating it pops up when you hit anything in the water. You should be able to drive your boat with no pressure from you. Water pressure pushes the 2 tabs down when they are properly adjusted.
Wed Apr 15, 2009 6:37 am
It is hard to measure these props accurately without some kind of jig.I thought mine was a little worn until I went to prodrive for some maintence and had KP check my prop to see if I needed a new one.When we measured it one blade was a 1/4 inch longer than the other.Don't really know that happend.
Wed Apr 15, 2009 10:49 am
Wed Apr 15, 2009 12:39 pm
