It is currently Mon Apr 06, 2026 7:38 am
Reply to topic  [ 25 posts ]
 extra trim on grab bar
Post extra trim on grab bar
ok, yall try not to thread jack this thread up too bad
ive got the winch trim, added the second trim switch to my grab bar along with the xtra tachometer. have any of yall done this w/ the winch, and if so, how big was the wire u ran? i know several have done it w/ the hydraulic trim.. but i got a call in to peck and he referred me to laurence ( LL )on here who did it and said that he coudlnt get his to work.
any suggestions?
Wed May 06, 2009 6:32 pm
Profile YIM WWW
Post Re: extra trim on grab bar
Don't know how your winch is set up, but my 4 wheeler winch has a switch that is connected to probably a 16ga wire that runs to the solenoid. It operates the solenoid which carries the load from the battery to the winch by means of probably a 6 ga wire. So what i'm saying is that if you are going to a solenoid, keep the solenoid, battery, and winch fairly close, because they will have the heavy wire. The switch doesn't carry a load in that situation. If your battery is in the back of the boat, I would mount my solenoid under the back corner of the boat or under the battery box lid and connect them together with 6 ga. wire, then come from my solenoid to my winch in the front with a 4 or 2 ga wire.
Wed May 06, 2009 8:02 pm
yea i was thinkin have to be at least a #2 wire, pretty good voltage drop even thou it aint but 3' from back da boat.. hell it takes a #8 to run from the winch to the motor trim, and thats only lil more than a ft!
i need to look at mounting a relay maybe.
Wed May 06, 2009 8:06 pm
Profile YIM WWW
Dang Good Idea SwampSnypers ~ six guage ware will carry most loads ..... Huh ?
Wed May 06, 2009 8:08 pm
Here, Hook up your winch to this solenoid, then the solenoid to the battery, #8 will probably work for this. I thought you were going to the winch in the front of the boat. Put your solenoid in the battery box or under the back corner of your boat. Might want to add a curcuit breaker in the line. Come off the soleniod with 16 ga. wire to a momentary on-off-on switch mounted to the handle bar. A drawing will come with the solenoid. I just bought one to replace the one on my 4 wheeler.
http://cgi.ebay.com/ebaymotors/WARN-WIN ... ccessories
Thu May 07, 2009 5:21 am
Thu May 07, 2009 5:31 am
If u don't run a relay you will eventually burn up your toggle/rocker switch because they are only good for so many amps. Now as forward as the wire from the winch to the battery I would think a 10guage wire would be sufficient, if u want to go a Lil bigger run an 8guage. Anything bigger is simply overkill. But even tho a 16 guage wire will work the winch now I think once u really have a load on the winch and its starving for juice a small wire will just burn up
Thu May 07, 2009 12:41 pm
My butt pirate buddy Sanders told me to ask you this.
But if you can't figure out how to wire up an electric fuel pump, how in the sam hell do you think you will be able to figure out a relay/toggle switch set up?
:D :D :?:
Thu May 07, 2009 12:48 pm
Thu May 07, 2009 3:45 pm
Did not take long to thread jack this thread! :o :lol:
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Thu May 07, 2009 3:50 pm
def. gona need a relay or solenoid.. ran #8, wouldnt trim up at all, and when i went to trim down, smoke come off the switch. lol.
river im over it now i had a good long convo w/ sum1 of higher inteligence than even u :mrgreen:
ps, you suck ;)
Thu May 07, 2009 6:26 pm
Profile YIM WWW
Smoked it !!!! :lol: :lol: :lol:
Thu May 07, 2009 7:42 pm
Thu May 07, 2009 8:28 pm
it's a good damn thing you play with high voltage and not current. :lol: :lol: :lol:
Thu May 07, 2009 8:38 pm
Thu May 07, 2009 9:54 pm
Fri May 08, 2009 7:12 am
Fri May 08, 2009 7:37 am
Fri May 08, 2009 8:00 am
Why they didn't have all that stuff when I was single :x
Love me some cougar :D
Fri May 08, 2009 8:06 am
Fri May 08, 2009 9:15 am
Got dayum....rippin the wind out of a man's sail....dat's cold :D
I can always be a sugar daddy to a young twenty somethin ;)
Fri May 08, 2009 9:22 am
Fri May 08, 2009 9:45 am
Rivers, can I borrow some of you AARP money? :?:
Fri May 08, 2009 9:50 am
Fri May 08, 2009 7:53 pm
Fri May 08, 2009 8:54 pm
Profile YIM WWW
