It is currently Fri Apr 03, 2026 2:09 pm
Reply to topic  [ 3 posts ]
 help using boat and it died
Post help using boat and it died
my prodrive 32hp 2006 just died the motor runs great but you put it in gear and it shuts it down. the motor has a mikuni carb and a evt exhaust with a rev limit help soon while i have coverage
Sat May 16, 2009 12:33 pm
Post Re: help using boat and it died
check around your prop on the shaft and see if you have any nylon string bogging down the motor if not, and it kinda just idles itself down tikl it dyes your going to need to bend you idle tab out. is it a sudden die or less and less rpm then dyes?
17x54 custom CC with stage 3 GTR.
Sat May 16, 2009 1:09 pm
You may need to clean out your pilot jet (I believe that's it)
Take bowl off carb carefully not to damage the gasket, unscrew the jet, spray w/ carb cleaner and blow out w/ compressed air.
Only takes a few minutes to do...easy place to start
I'm guessin you made it off the water?? Just noticed the time you posted thread
Sat May 16, 2009 5:13 pm
