| water in belt housing http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=2168 |
| Author: | darrel from meraux [ Wed May 20, 2009 7:50 pm ] |
| Post subject: | water in belt housing |
i hosed off my gt last run and last time i started it it sprayed water out what seemed to be the clutch but after looking i noticed i had filled up the belt housing about 3-5 inches up. since theres no drain i know about and this will surely dry rot the belt how do yall get the water out of yall's? |
| Author: | Gator Guy [ Wed May 20, 2009 7:59 pm ] |
| Post subject: | Re: water in belt housing |
there should be a drain, on the front of the belt housing, if not jus pull the clutch cover off and crank up the motor, the belt will sling it out. |
| Author: | dog walker [ Wed May 20, 2009 8:06 pm ] |
What GG said |
| Author: | stanco [ Wed May 20, 2009 9:31 pm ] |
would be super easy to drill and tap on the bottom if there isnt one on your housing. |
| Author: | muddiejeep [ Thu May 21, 2009 7:31 am ] |
use a small hose and siphon |
| Author: | River [ Thu May 21, 2009 9:31 am ] |
Buy a PD and don't worry about it. |
| Author: | Dizzimator65 [ Thu May 21, 2009 12:18 pm ] |
WHAT STANCO SAID. THAT WAY YOU HAVE A PERMANENT DRAIN W/O THE NEED TO OPEN THE DRIVE. |
| Author: | deltaduckmaster [ Thu May 21, 2009 5:46 pm ] |
| Author: | quackconsumer [ Fri May 22, 2009 5:36 am ] |
Maybee you have an older model but my gt has a screw in da front to drain it out |
| Author: | dog walker [ Fri May 22, 2009 5:41 am ] |
He has an older model |
| Author: | Ace [ Fri May 22, 2009 6:04 am ] |
Pulled my screw last nite, had about a cup of rainwater in belt housing. Keep my motor covered and that keeps most of the rain out |
