| Salt water on prodrive http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=2246 |
| Author: | swamprooter [ Tue May 26, 2009 2:11 pm ] |
| Post subject: | Salt water on prodrive |
Thinking about converting my 1854 phowler 36 PD into a spot and stalk redfish death machine. Anything I did to know about Salt water or things I need to do before or after i take it in the drink? thanks |
| Author: | coondik [ Tue May 26, 2009 2:18 pm ] |
| Post subject: | Re: Salt water on prodrive |
S_R: i wash mine with Salt Away & fresh water, let dry, den spray de entire thing wit WD-40 & wipe off excess wit a rag after each use. You can pick up dat Salt Away @ Acedemy or West Marine. Also, pick up some di-electric grease & grease all de electrical terminals / connections throughout u'r motor. |
| Author: | swamprooter [ Tue May 26, 2009 2:39 pm ] |
Thanks Coondik, we have a place at Empire and just got to thinking i need to be bowfishing more and maybe flyfishing for reds instead hanging off a well trying to time the specs. Thanks for the advice.. |
| Author: | forever draggin [ Tue May 26, 2009 5:08 pm ] |
coondick gave you some really good advice, down here saltwater will tear anything up if u let it. as stated above i would rinse the motor when finished and grease all of your connections. |
| Author: | darrel from meraux [ Tue May 26, 2009 6:14 pm ] |
all i ever run is salt. if you religiously rinse down your motor after every run, wd your electric, and grease at recommended intervials you wont have a problem. I have a 3-4 yr old gdlt thats in great condition and all it's ever seen was salt. |
| Author: | Sand Man [ Wed May 27, 2009 8:52 am ] |
I don't run salt a lot, but when I do I douse everything in Corrosion X in the red can and then rinse with fresh water when I'm done. Haven't had a problem. |
| Author: | tongthrower [ Wed May 27, 2009 9:41 am ] |
I see a new muffler in your future... |
| Author: | Wilson [ Wed May 27, 2009 10:57 pm ] |
| Author: | swamprooter [ Thu May 28, 2009 7:11 am ] |
Thanks guys for the help. |
| Author: | Sand Man [ Thu May 28, 2009 7:42 am ] |
