BradS
Joined: Wed Jan 14, 2009 5:23 am Posts: 4514 Location: Lafayette, La
 Hyd. Trim on PD
Is there a fuse somewhere on the trim? Mine just decided to stop workin.
I have 2 switches and changed em out and neither one of them worked.
| Sat May 30, 2009 4:12 pm |
mudd
Joined: Wed Jan 14, 2009 5:44 pm Posts: 443 Location: Wisconsin
 Re: Hyd. Trim on PD
Check the 3 wires going into the motor.
_________________ THE, FIRST and ONLY MMT Member of the Year!
| Sat May 30, 2009 6:00 pm |
BradS
 Re: Hyd. Trim on PD
I took my test light and tested for constant power and had it. Pushed up on the switch and the top post got hot. Pushed down on the switch and the bottom post got hot. Checked the 3 wires going into the motor and the black had no power (didnt think it would but I checked) On the other 2 when I pushed the switch up one had power and when I pushed the switch down the other had power.
Im thinking the pump is bad.
Any other ideas? Is there a reset on the motor somewhere?
| Sat May 30, 2009 6:40 pm |
POKER1
Joined: Tue Jan 13, 2009 8:02 pm Posts: 6243 Location: Bossier City
 Re: Hyd. Trim on PD
Check the wires where they go into the trim motor. Mine went out due to a wire break right at the pump. Wires were a little to short and the constant pulling on the wires finally did them in. PD rewired the pump with long leads and no more trouble. Wire actually broke inside the rubber gromet in the housing.
_________________ 18x48 Charles Leonard / 36PD
| Sat May 30, 2009 10:34 pm |
BradS
 Re: Hyd. Trim on PD
The looks fine. Sucks cause I was gonna go for a ride today for the 1st time in a while.
Oh well, Ill just go for a ride when I get home from work in 2 weeks.
| Sun May 31, 2009 4:59 am |
quackconsumer
 Re: Hyd. Trim on PD
Sounds like da motor for your hydrolics is bad.
| Sun May 31, 2009 5:28 am |
POKER1
 Re: Hyd. Trim on PD
| Sun May 31, 2009 8:54 am |
mudd
 Re: Hyd. Trim on PD
Yea what he said ^
| Sun May 31, 2009 10:33 am |
stanco
 Re: Hyd. Trim on PD
Why could you not still ride? If the hydraulics go out does the ratchet thing not work either?
| Sun May 31, 2009 9:51 pm |
Gatorpoint
Joined: Tue Jan 13, 2009 8:09 pm Posts: 1175 Location: A slough behind you, TEXAS
 Re: Hyd. Trim on PD
_________________ 1854 Brotha Breaux Bateau pullin' a 35 GT arrrrahhh! Willett Welding custom boat trailer
| Sun May 31, 2009 9:57 pm |
BradS
 Re: Hyd. Trim on PD
Eh Its at Pro Drive now. I bet it works when I get it back
| Mon Jun 01, 2009 7:37 am |
River
Joined: Wed Jan 14, 2009 8:34 am Posts: 1092 Location: Unaffiliated, SETX group has caused me to renounce my Texas Citizenship
 Re: Hyd. Trim on PD
_________________ "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the outcome of the vote."-Benjamin Franklin
| Mon Jun 01, 2009 3:44 pm |
