| 32 pd with a problem http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=4089 |
| Author: | Sonny13 [ Fri Aug 21, 2009 9:30 pm ] |
| Post subject: | 32 pd with a problem |
My pd has a problem. The rod that the chain link is atached to hold up the motor rubs against the engine. also the motor moves back and forth on the joint where the motor and cluth assembly mate to the lower unit drive. Is this a seal or is it the bushing inside that is bad. Any help is much needed and apriciated. |
| Author: | LA OUTLAW [ Fri Aug 21, 2009 10:43 pm ] |
| Post subject: | Re: 32 pd with a problem |
There should be some slack in that joint but the stud should not be hitting the motor I have Hyd T&T and my stud was the same length as the one with the chain so I cut it and made it looke like the other one... |
| Author: | Mitschke [ Fri Aug 21, 2009 10:58 pm ] |
Pump it with grease, then tighten you tension knob. Edit- i re read your post. Im not sure if i quite understand. |
| Author: | Sonny13 [ Sat Aug 22, 2009 10:47 pm ] |
The bar that the chain link is welded to is strait up and down( i just put a square on it) and it is still hit in the motor. I tightened all the mountin bolts and put greese in it. The "slack" is that when i push down on the tiller arm the motor moves 3/4 to an inch befor the lower unit comes up. sorry about the unclairity. |
| Author: | POKER1 [ Sat Aug 22, 2009 11:08 pm ] |
Something ain't right. The play from the reverse plate is side to side. All your bolts tight? Where you located at? |
| Author: | dpd [ Sun Aug 23, 2009 5:56 am ] |
I think TBS has it correct. I have a 36pd with the manual trim and I have a small aluminim block and chain link mounted on the longer stop rod. I knocked the crap out of something last weekend and it bent the shit out of it. Which is what is supposed to happen unless you want the motor in the boat with you. You will either have to take a substantial piece of cheater pipe that slides on the rod stop that allows you to bend it back like it was, or replace it. I have not been able to do either yet as I don't have the right size cheater pipe, and I can't get the damn thing out in order to replace it. |
| Author: | Sonny13 [ Tue Aug 25, 2009 8:05 pm ] |
Poker1 , Im in wisconsin. I just dont know if it is a seal or if it is the bushing down the drive shaft. Really starting to piss me off, Gooses season is only 7 days away. |
| Author: | forever draggin [ Tue Aug 25, 2009 10:09 pm ] |
y dont u upload a quick vid so everyone can help get u going |
| Author: | POKER1 [ Tue Aug 25, 2009 11:08 pm ] |
Takes less than an hour to pull the power head off, drop the lower unit and then reassemble. I'd pull it and find out. |
| Author: | Sonny13 [ Mon Aug 31, 2009 7:06 pm ] |
thinks thats what I will have to do. Maybe tomorow durnin down time of the goose hunt. thanks again |
| Author: | POKER1 [ Mon Aug 31, 2009 7:57 pm ] |
Mine doesn't have any play like you have described. |
| Author: | BradS [ Mon Aug 31, 2009 9:03 pm ] |
My 32 did the same thing. I just took a piece of pipe and bent it back to the front of the boat. Finally I just cut it off once I got the Hyd TnT |
| Author: | UNCLE-J [ Mon Aug 31, 2009 10:15 pm ] |
If the pipe is hitting engine, spend the extra money and put Hydro Trim, and cut the pipe.. That is what I did.. |
| Author: | wifowler [ Fri Sep 04, 2009 7:49 am ] |
