outboard runnin lillies
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=41267
Author:  fowllife08 [ Fri May 31, 2013 5:36 am ]
Post subject:  outboard runnin lillies
I saw a guy last year hunting in the north flats with a regular outboard. While 90% or us where running some sort of mm. He was going everywhere we were going. Including the thick lillies like they weren't there. I thought to myself aside from the jack plate he has to have something else. Low and behold he pulls up to the ramp and pulls off some type of fin from the bottom of his boat. My questiin is what is it and where can I get one?
Author:  OwenDickeson [ Fri May 31, 2013 5:48 am ]
Post subject:  Re: outboard runnin lillies
Where you at? It's a lilly keel.
Author:  bobbyjober [ Fri May 31, 2013 5:51 am ]
We have run 25 hp tunnel boats with keel for years. They really work great , just always have the worry of overheating with a water pump. PM some of the boat builders on here, they will point you in the right direction.
Author:  fowllife08 [ Fri May 31, 2013 5:53 am ]
Around opelousas area. I plan on gettin a gtr but in the mean time while trying to pay for wedding amd savin up I need something kinda like this.
Author:  OwenDickeson [ Fri May 31, 2013 6:07 am ]
Brother is around 30-40 miles from you.
Author:  fowllife08 [ Fri May 31, 2013 6:13 am ]
He makes them? Where's he located?
Author:  OwenDickeson [ Fri May 31, 2013 6:15 am ]
Check your PM's
Author:  BayouBugs [ Fri May 31, 2013 7:02 am ]
probably had screens over his intakes on his outboard for preventing vegetation from getting in his pump. With screens and a jack plate, keel guard, you can go just about anywhere with an outboard.... but not quite everywhere you can with a mm.
Author:  fowllife08 [ Fri May 31, 2013 7:16 am ]
I don't doubt that bb. Just lookin for a temporary setup for now to do a little fishin a froggin'. Hopefully I have a mm by august. Just have to see how the cards are played. Thanks for the replys guys
Author:  kibb [ Fri May 31, 2013 7:35 am ]
While your at it, extend your tattle tell along the side your boat and make it piss to the front and off to the side in front of the drivers seat. Now you won't have to keep looking back to see if the water pump is working.
Author:  fowllife08 [ Fri May 31, 2013 8:44 am ]
Where can I buy an extension? Like west marine? Also is there some type if screen you can put over your inlet for less debris gettin in?
Author:  Will [ Fri May 31, 2013 8:59 am ]
http://www.theultrajack.com/products.htm
Author:  OwenDickeson [ Fri May 31, 2013 9:34 am ]
Brother can fix you up a screen too.
Author:  OwenDickeson [ Fri May 31, 2013 9:45 am ]
Author:  fowllife08 [ Fri May 31, 2013 9:51 am ]
Will that's awesome! Owen that's exactly what I was talkin about
Author:  Kmoppert [ Fri May 31, 2013 10:29 am ]
Author:  OwenDickeson [ Fri May 31, 2013 10:41 am ]
Mrs Claudia
Tell her Owen says hello.
Author:  fowllife08 [ Fri May 31, 2013 11:09 am ]
Anybody run that jack plate???? What's it all about?
Author:  kibb [ Fri May 31, 2013 11:56 am ]
Author:  kibb [ Fri May 31, 2013 11:57 am ]
Run the jackplate with a tunnel to get the cavitation plate level with the top of the tunnel.
Author:  fowllife08 [ Fri May 31, 2013 12:10 pm ]
Kibb I talked to the guy that sells those jack plate and he has an extension that comes with it and all the hardware.
Author:  pearl river outlaw [ Fri May 31, 2013 12:18 pm ]
Author:  bobbyjober [ Fri May 31, 2013 12:57 pm ]
http://www.youtube.com/watch?v=NVOfwqncnY4
This 25 hp Mercury on a mudflat is crazy. Many of you have seen it before, but it is still a good example of what the right setup can accomplish.
Author:  fowllife08 [ Fri May 31, 2013 1:18 pm ]
Thays bad a$$. I saw that 40 merc doin some stuff like that.
Author:  bobbyjober [ Fri May 31, 2013 1:20 pm ]
http://www.youtube.com/watch?v=F8Meh_wA5l4
40 Merc running grass and shallow ditch.
Author:  fowllife08 [ Fri May 31, 2013 1:35 pm ]
They got the same guy runnin some flats. Only thing I'm worried about with that keel is hitting stuff. The jack plate seems more feasible for what I wanna do, plus it has a keel.
Author:  huntingsmith [ Fri May 31, 2013 2:36 pm ]
May be able to run a mudflat bt he ain't stoppin. He says dead stop. We all see he doesn't
Author:  Marshrat823 [ Fri May 31, 2013 8:16 pm ]
Author:  netman [ Sat Jun 01, 2013 6:33 am ]
Fowl, you,others and myself are overly impressed with that lilly cutter. I went with T al to the Basin last year in early summer. He put that lilly cutter on his boat when we left the ramp. My jaw was locked wide open with what that boat cut through that day. To this day I am still memorized with what his boat did. He has a seventeen foot crawfish skiff, jackplate, stainless mesh over intake and the lillty cutter. That boat is set up perfect. However one must always be looking back to make sure the motor does not overheat. We would stop every now and then in the clear and let the motor run clean water to ensure the mesh was not clogged up. His boat had a Yamaha 85 two stroke on it. Its a Dugas skiff. Its a F...ing awesome rig. If I ran anything like what we did that day I would have its twin. Those crawfisherman know how to get'r done.
Author:  huntingsmith [ Sun Jun 02, 2013 9:42 am ]
^^^ dem dugas skiffs are top notch. Nothing built likem anymore.
Author:  fowllife08 [ Sun Jun 02, 2013 11:04 am ]
Coulda used this unit last night. Went froggin in henderson and the lillies were bad! My lil 25 was a strugglin while the rest of em with there sd's were just cruisin right along lol. Oh well I ended up callin terry with the ultra jack. Went ahead and ordered one. Should be a couple weeks before he finishes up with it.
Author:  ibfishin [ Mon Jun 03, 2013 7:39 pm ]
Author:  fowllife08 [ Mon Jun 03, 2013 8:37 pm ]
Just makin sure I didn't waste my money. I opted to go with the 35 gtr but I will have to wait a little longer. In the mean time this is the setup I will be running
