It is currently Tue Mar 31, 2026 11:54 am
Reply to topic  [ 15 posts ]
 32 pd with a problem
Post 32 pd with a problem
My pd has a problem. The rod that the chain link is atached to hold up the motor rubs against the engine. also the motor moves back and forth on the joint where the motor and cluth assembly mate to the lower unit drive. Is this a seal or is it the bushing inside that is bad. Any help is much needed and apriciated.
1648 PD
32pd
Fri Aug 21, 2009 9:30 pm
Post Re: 32 pd with a problem
There should be some slack in that joint but the stud should not be hitting the motor I have Hyd T&T and my stud was the same length as the one with the chain so I cut it and made it looke like the other one...
1754 GT EXTREME 37EFI
Fri Aug 21, 2009 10:43 pm
Pump it with grease, then tighten you tension knob.
Edit- i re read your post. Im not sure if i quite understand.
Fri Aug 21, 2009 10:58 pm
The bar that the chain link is welded to is strait up and down( i just put a square on it) and it is still hit in the motor. I tightened all the mountin bolts and put greese in it. The "slack" is that when i push down on the tiller arm the motor moves 3/4 to an inch befor the lower unit comes up. sorry about the unclairity.
1648 PD
32pd
Sat Aug 22, 2009 10:47 pm
Something ain't right. The play from the reverse plate is side to side. All your bolts tight? Where you located at?
18x48 Charles Leonard / 36PD
Sat Aug 22, 2009 11:08 pm
I think TBS has it correct.
I have a 36pd with the manual trim and I have a small aluminim block and chain link mounted on the longer stop rod. I knocked the crap out of something last weekend and it bent the shit out of it. Which is what is supposed to happen unless you want the motor in the boat with you. :twisted:
You will either have to take a substantial piece of cheater pipe that slides on the rod stop that allows you to bend it back like it was, or replace it.
I have not been able to do either yet as I don't have the right size cheater pipe, and I can't get the damn thing out in order to replace it.
Sun Aug 23, 2009 5:56 am
Poker1 , Im in wisconsin. I just dont know if it is a seal or if it is the bushing down the drive shaft. Really starting to piss me off, Gooses season is only 7 days away.
1648 PD
32pd
Tue Aug 25, 2009 8:05 pm
y dont u upload a quick vid so everyone can help get u going
Tue Aug 25, 2009 10:09 pm
Takes less than an hour to pull the power head off, drop the lower unit and then reassemble. I'd pull it and find out.
Tue Aug 25, 2009 11:08 pm
thinks thats what I will have to do. Maybe tomorow durnin down time of the goose hunt. thanks again
1648 PD
32pd
Mon Aug 31, 2009 7:06 pm
Mine doesn't have any play like you have described.
Mon Aug 31, 2009 7:57 pm
My 32 did the same thing. I just took a piece of pipe and bent it back to the front of the boat. Finally I just cut it off once I got the Hyd TnT
Mon Aug 31, 2009 9:03 pm
If the pipe is hitting engine, spend the extra money and put Hydro Trim, and cut the pipe.. That is what I did..
Mon Aug 31, 2009 10:15 pm
Fri Sep 04, 2009 7:49 am
