It is currently Sun Apr 12, 2026 11:31 am
[ 4 posts ] |
themilkman
 23 go devil sd no spark?
Only one cylinder has spark got a new ignition coil for the other cylinder now both dont have spark?
| Sun Nov 03, 2013 4:50 pm |
themilkman
 Re: 23 go devil sd no spark?
I unplugged the kill switch wires from both ignition coils now both have spark is it alright to run it with out the kill switch wires and just use the key to turn it off?
| Sun Nov 03, 2013 5:04 pm |
msm8281
No...its not alright. Its there to kill the motor in an emergency. Find the problem and fix it.
| Sun Nov 03, 2013 5:11 pm |
p5388
Joined: Wed Jul 24, 2013 9:16 pm Posts: 232 Location: Deep East Texas
The diode in the wire going to the coil that works has gone bad and back-feeding to the coil that has no spark. In emergency it is safe to run with just the 1 kill wire disconnected (the coil that has no spark when wire is connected) as long as your anti-backfire solenoid on the carburetor is still functional - when you turn the key off, or kill lanyard is pulled, the anti-backfire solenoid (closes fuel delivery inside the carburetor to the engine) and the 1 coil still connected to the switch(es) will shut the engine down...
The replacement wire set should be around $10-$15
_________________ The key to a successful marriage? Give a man a 4X4 truck, a rifle, a shotgun, a Mud boat, and a fishing pole - he will be out of your hair most of the year...
| Sun Nov 03, 2013 9:40 pm |
[ 4 posts ] |
