It is currently Wed May 27, 2026 6:30 am
[ 7 posts ] |
Is a G31648VBLW good boat for SD?
buckshot4
Joined: Sat Nov 23, 2013 8:19 pm Posts: 3 Location: Milwaukee, WI
Im thinking about buying a G3 boat with a 27 Pro Drive SD. Is this a good combo for the motor because of the slightly modified V on bow? Any help would be great.
| Sat Nov 23, 2013 8:26 pm |
DuckHunter251
Joined: Mon Jan 24, 2011 5:00 pm Posts: 233 Location: Milledgeville, GA
 Re: Is a G31648VBLW good boat for SD?
Had 27 pro drive on 1548 g3 and it was a dog.
_________________ 1846 GTB with GTR 35
| Sun Nov 24, 2013 9:21 pm |
buckshot4
How much of a difference does the transom height make? Is a 20" better than a 16"?
| Sat Nov 30, 2013 7:58 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
It's makes a huge diffrence. If the motor is a short transom, the boat needs to be a short transom.
_________________ You have your whole life to be an idiot, take a day off!
| Sun Dec 01, 2013 5:15 am |
Gigafowl
G3 - works great with a Yamaha....
Thats what it was R & D-ed for....
If you want a certain SD get the hull that was R & D-ed to work best for it....
| Sun Dec 01, 2013 8:13 am |
buckshot4
The motor is a short shaft. I thought as long as you have both it should be ok. How low should the prop be under the boat? I have had some guys say a 20" is better to keep the prop higher but, this didn't make sense to me.
| Sun Dec 01, 2013 8:43 am |
DuckHunter251
If it's short transom motor go short transom hull. If you mix st motor and tt hull the motor will not perform.
| Sun Dec 01, 2013 12:56 pm |
[ 7 posts ] |
