It is currently Wed May 27, 2026 5:45 am
Reply to topic  [ 7 posts ]
 Is a G31648VBLW good boat for SD?
Post Is a G31648VBLW good boat for SD?
Im thinking about buying a G3 boat with a 27 Pro Drive SD. Is this a good combo for the motor because of the slightly modified V on bow? Any help would be great.
Sat Nov 23, 2013 8:26 pm
Post Re: Is a G31648VBLW good boat for SD?
Had 27 pro drive on 1548 g3 and it was a dog.
1846 GTB with GTR 35
Sun Nov 24, 2013 9:21 pm
How much of a difference does the transom height make? Is a 20" better than a 16"?
Sat Nov 30, 2013 7:58 pm
It's makes a huge diffrence. If the motor is a short transom, the boat needs to be a short transom.
Sun Dec 01, 2013 5:15 am
G3 - works great with a Yamaha....
Thats what it was R & D-ed for....
If you want a certain SD get the hull that was R & D-ed to work best for it....
Eat - Sleep - Hunt ! ! !
Sun Dec 01, 2013 8:13 am
The motor is a short shaft. I thought as long as you have both it should be ok. How low should the prop be under the boat? I have had some guys say a 20" is better to keep the prop higher but, this didn't make sense to me.
Sun Dec 01, 2013 8:43 am
If it's short transom motor go short transom hull. If you mix st motor and tt hull the motor will not perform.
Sun Dec 01, 2013 12:56 pm
