It is currently Sat Dec 20, 2025 6:51 am
Reply to topic  [ 4 posts ]
 mounting a mudmotor on 15' jon boat
Post mounting a mudmotor on 15' jon boat
looking to replace the transom on my 15' foot jon boat. to put a 23 hp surface drive mudbuddy. any advice on removing the rivets to replace the old wood with new wood. thinking of going with s.s. bolts and nuts in place of the rivets there is some pic attached. any advice helpful thank you
Wed Feb 05, 2014 6:23 pm
Post Re: mounting a mudmotor on 15' jon boat
I would just drill out the rivets, pull the wood you need, out of there, put fresh wood if you must do it, and then go back with stainless bolts and sealant!
Make sure you reinforce the transom as much as possible! Mudmotors give a transom hell!
Thu Feb 06, 2014 1:29 pm
Maybe get a local welder to rebuild it out of aluminum. My cousin had to do that on his 1546, had the wood trans for 2 weeks before the gdsd messed it up. Not a single problem after the rebuild.
35 GTR chasin a BBC 1848
Thu Feb 06, 2014 2:27 pm
Thu Feb 06, 2014 2:30 pm
