It is currently Wed Apr 08, 2026 4:49 pm
Reply to topic  [ 3 posts ]
 water coming out of back seal?????
Post water coming out of back seal?????
was pumping new grease in motor when i pulled the screw out a little water came out what should i do?
Wed Oct 28, 2009 7:08 pm
Profile YIM
Post Re: water coming out of back seal?????
Make sure the O ring is still on the little screw. If it was just a little water I would see if it happens again, if it does you may need to replace your seal.
Wed Oct 28, 2009 7:39 pm
I'd just keep an eye on it for now,I think I had that once before and it has never happened again.Run it and pull the screw when you get home after it sits a little while and pump some grease and check for water.
Thu Oct 29, 2009 5:19 am
cron
