| water coming out of back seal????? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=5704 |
| Author: | duckmanck [ Wed Oct 28, 2009 7:08 pm ] |
| Post subject: | water coming out of back seal????? |
was pumping new grease in motor when i pulled the screw out a little water came out what should i do? |
| Author: | quackconsumer [ Wed Oct 28, 2009 7:39 pm ] |
| Post subject: | Re: water coming out of back seal????? |
Make sure the O ring is still on the little screw. If it was just a little water I would see if it happens again, if it does you may need to replace your seal. |
| Author: | dog walker [ Thu Oct 29, 2009 5:19 am ] |
I'd just keep an eye on it for now,I think I had that once before and it has never happened again.Run it and pull the screw when you get home after it sits a little while and pump some grease and check for water. |
