It is currently Wed Apr 08, 2026 3:09 pm
Reply to topic  [ 22 posts ]
 Need exhaust advice
Post Need exhaust advice
I got the new rig and i have put about 7 hours on it and I wont to put a new muffler on it. I have a 35 gtr and I was just wondering what everyone was running and how you like the sound.
Wed Oct 28, 2009 10:32 pm
Post Re: Need exhaust advice
go with an EVT!
go to extremevtwins.com
Thu Oct 29, 2009 6:47 am
Thu Oct 29, 2009 7:10 am
Do your research Bro. They all are high like girraffe pussy, so get the best bang for your buck. Dont just HOP on da bandwagon!
Thu Oct 29, 2009 7:33 am
17x48 extreme stage 2 GTR
Thu Oct 29, 2009 7:38 am
I got about 30 hrs on the marsh mellow I got from GT. Its still goin strong. Call GT they can help you out.
BUCK OFAMA
Thu Oct 29, 2009 6:37 pm
MMT Moderator
I just bought Marsh Mellow, upgrading from Stock Exhaust... Install & review to come Saturday...
GTB 1860 w/ 2019 GTR40XD-HO
Thu Oct 29, 2009 7:27 pm
Let me know how you like the Marsh Mellow exhaust, that is the one I was thinking of getting. Is there one out there that is the style of the Marsh Mellow but you can adjust the sound?
Thu Oct 29, 2009 8:53 pm
MMT Moderator
Thu Oct 29, 2009 9:39 pm
To comment on what was said above about the brackets breaking on EVT exhaust. I have never heard of a bracket breaking but I had a baffle break on the inside of mine and it was no problem I shipped off the old one to EVT and they replaced it...
1754 GT EXTREME 37EFI
Thu Oct 29, 2009 9:48 pm
MMT Moderator
I've seen a broken bracket like what was mentioned above... I've broken my stock brackets noticed that when I was removing the exhaust.
Thu Oct 29, 2009 9:52 pm
Uncle J 1948 holding a LT
Uncle J 1848 w/?
Thu Oct 29, 2009 10:00 pm
I know im asking alot of questions but I just wont to do this right the first time. Does anyone know how the performance is on one with a silencer? This is my first mud motor so any advice you can give me will help.
Fri Oct 30, 2009 12:40 am
MMT Moderator
Run the stock exhaust in SS if your worried about "loud" sound... I've never had an issue with "scaring" away ducks to never return...
I usually arrive to my spot at least an hour before shooting time.
Fri Oct 30, 2009 7:17 am
Uncle J 1848 w/?
Fri Oct 30, 2009 8:30 am
We build our own, Using Bisquit style replacement mufflers you can buy for about $6.00 at your local lawn mower shop. We use the header flanges off stock exhaust, and weld a 1"x3" long pipe nipple to it. Then using a 1" pipe coupling screwed on to it, we screw in a 1"x2" nipple into coupling. Then muffler is screwed on . We have built about 3 dozen sets of these for our hunting buddies with good results. We've put them on all makes of mudmotors and they last about 2 seasons. A few of the guys said they picked up a couple hundred rpm after installing them.??? They sound about like a Harley Sportster from a distance. Total cost about $20.00.
Fri Oct 30, 2009 1:10 pm
Fri Oct 30, 2009 1:18 pm
I have the evt loud exhaust on my GTR. 55 hours and so far nothing has broke. But i dont run mine as hard as some of the guys on here. Do your research and find which one will best fit your needs.
2060 CC 3/4 Gator-tail 1/4 Brother Breaux Boat /35GTR
Cowboy thought- a thong on a woman is like a barbed wire fence. It protects the property but doesnt obstruct the view.
Fri Oct 30, 2009 1:48 pm
Fri Oct 30, 2009 11:04 pm
18x48 Charles Leonard / 36PD
Fri Oct 30, 2009 11:26 pm
Brads, I wish I had the capability to send photos,I have had probably a hundred inquiries about this muffler fix. My buddies and I got tired of replaceing stock and performance exhaust systems do to broken welds and brackets. This system doesn't use any kind of bracket. Flange bolts hold header pipe and muffler, the whole System doesn't weigh much more than a pound per cyclinder, and the replacement mufflers are cheap and easy to replace, Just screw them on the threaded pipe nipple. I carry a extra set of mufflers in my boats tool box, in case one of them blows out. I have had to replace mufflers twice on my Big Block Van which has 220 hrs on it. The mufflers I use are rated for 12-16Hp single cyclinder Briggs engines, and are sold by O'rielys auto parts.
Sat Oct 31, 2009 6:57 pm
Thanks for the info I just ordered the BPS exhaust.
Mon Nov 02, 2009 8:34 pm
