It is currently Sat Apr 04, 2026 12:19 pm
[ 5 posts ] |
slingshot
 Anyone ever done this
Has any of yal ever bought just a surface drive frame and put there old motor on it just wondering.
_________________ 1542 stuck to a 27mini. She gone. 1746 with a modded 35 gdsd Capt Team total asalt
| Thu Nov 05, 2009 10:12 pm |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
 Re: Anyone ever done this
I heard of it. I know their are guys who want to.
_________________ BUCK OFAMA
| Thu Nov 05, 2009 10:27 pm |
POKER1
Just have to find someone willing to sell you a frame.
| Thu Nov 05, 2009 10:38 pm |
50fps
Swapped a 23 onto a MB Frame a few years back. I also tried to get a GTR frame for a 27 Kohler, but was told it wasn't cost effective even tho they use to offer the GT with a Kohler. So I think I'm just gonna have MWSC build me up a 25/27 PD instead.
| Fri Nov 06, 2009 5:10 am |
DENNYEDWARDS
My first mudmotor was a 2004 18hp MB Hyper, short transome frame,after two seasons and 120Hrs we swapped motor out for 35 Van Big block on the 18hp frame. We had to modify motor mounting plate by adding 1/1/4"x3/16" strap steel to both sides and front of mount. Also had to relocate tiller bracket away from motor. Big blocks motor base hole spacing is wider and longer, so we had to add the strap steel to accomodate this. We also had to modify the frame the belt housing bolts to, by elongating the the holes. Big block is 1" taller at shaft center than small block. Belt tensioner bolt bracket needed modded also. We ordered new upper gear from MB to replace 32T 18hp gear,with a 36T. We have 230Hrs on this swap and it Has beentrouble free. We have also modified 9Hp GD Crawfish model to 29hp Big Block Van. This swap was a lot of fun, And a challenge.
| Fri Nov 06, 2009 9:11 am |
[ 5 posts ] |
