It is currently Mon Dec 22, 2025 2:59 pm
[ 7 posts ] |
jakefromflorida
 older 27hp prodrive
Just bought my first surface drive and trying to become acquainted with it and educated on all the moving parts...
Is there a owner manual or a exploded view of the drive shaft assembly? I'm assuming the motor block is nothing more then a mower engine, so I could use that parts list. What motors does pro drive use?
Just looking for all and any information on it so I can learn more about it. I also need to replace the Skeg eventually, it has a nice 2 inch crack at the very bottom...
Other then that does anyone have a list of suggested maintenance chores to do at specific hours? It only has roughly over 100 and runs solid, and oil changed regularly.
Thanks in advance.
| Mon Feb 23, 2015 12:37 pm |
jakefromflorida
 Re: older 27hp prodrive
It's a 2003, and I've just learned I may need to replace the top seal. Draining it now and about to flush it. Once refilled I'll run it once and check it again. If still leaking where can I get the top seal at? If not too bad to replace, I might do the bottom as well.
Thanks in advance guys
| Mon Feb 23, 2015 3:57 pm |
jakefromflorida
Well, drained and flushed the lower unit. Took it for a spin and had this sitting on top. I'm assuming I definitely need to replace the top seal?
| Mon Feb 23, 2015 5:43 pm |
OwenDickeson
The prop seal needs to be replaced most likely. Call Pro-Drive tomorrow and ask for Peck.
| Mon Feb 23, 2015 6:02 pm |
jakefromflorida
Been talking with peck, he suggested just to flush/drain then run it again. After tonight I agree... Probably need that seal.
| Mon Feb 23, 2015 6:20 pm |
jakefromflorida
Just ordered the bottom seal from peck this afternoon. Going to tear it down next Monday or Tuesday and assess what else I need... Possibly top seal as well and I want to get a better look at the clutch assembly. Does anyone have a video or direct link when replacing these seals?
Thanks
| Tue Feb 24, 2015 1:02 pm |
jakefromflorida
I thought I remember reading something somewhere about using marine grade grease in correlation with the seals?!
Surely I read this incorrectly? I plan on doing my lower seal tomorrow and would like to know...
Just pull the prop, replace old seal, and put new nut on right?
Thanks
| Fri Feb 27, 2015 7:35 pm |
[ 7 posts ] |
