| Trailer tires weari'n funny on Godevil boat trailer http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=609 |
| Author: | Kelly [ Thu Feb 12, 2009 2:05 pm ] |
| Post subject: | Trailer tires weari'n funny on Godevil boat trailer |
I noticed both my trailer tires were wearing more on the inside tread. It doesn't appear the axle is bent, and the trailer itself is built sturdy by appearance (McClain). I never carried a real heavy load, maybe the guy I bought it from did. Anyone know a way to tell for sure if somthings out of wack? The spring brackets are welded in place, so I don't think the axle has shifted, both tires are showing the same wear almost like the trailer was grossly over loaded. |
| Author: | godvl [ Thu Feb 12, 2009 3:51 pm ] |
| Post subject: | Re: Trailer tires weari'n funny on Godevil boat trailer |
my friends does the same thing, his has been put through hell flyin down shity roads. ive seen a few do that |
| Author: | etquackster [ Thu Feb 12, 2009 4:09 pm ] |
mine did the same thing a tire guy told me air pressure is the cause of that |
| Author: | SwampSnyper [ Thu Feb 12, 2009 4:38 pm ] |
Spindle is probably bent up a little. Very common. Bouncing in potholes will do it. Glad we got good roads in La. |
| Author: | The Shafer [ Thu Feb 12, 2009 4:44 pm ] |
not to be opposite here, but mine wear on the outside more....hmmm. |
| Author: | SwampSnyper [ Thu Feb 12, 2009 4:49 pm ] |
It can very possibly be not perfect from the manufactor. Most trailers arn't perfect. If they are lasting a while before wearing to the point of needing to being changed, just roll with it. Trailer tires are usually made cheap any way. |
| Author: | Kelly [ Thu Feb 12, 2009 5:21 pm ] |
I don't think axles themselves are too expensive (I hope). I may just swap it out. There is a trailer place not too far from the house that may be able to change the spindles or at least check to see if thats the problem. If I didn't trailer the boat far, I'd let it roll. Our lease is about an hour from the house and I have to cross a long bridge (Bonnie Carrie/Lake Ponchatrain) and I'd hate to have a tire go out on that thing. I checked the axle itself this afternoon and it appears ok. I think the spindles are what's bent. |
| Author: | SwampSnyper [ Thu Feb 12, 2009 5:48 pm ] |
You can get them precision realigned. Not sure of the place but my dad had it done a few times on his boat somewhere in baton rouge. |
| Author: | River [ Thu Feb 12, 2009 6:02 pm ] |
| Author: | River [ Thu Feb 12, 2009 6:03 pm ] |
| Author: | Gatorpoint [ Thu Feb 12, 2009 6:03 pm ] |
| Author: | Kelly [ Thu Feb 12, 2009 7:24 pm ] |
Yep, crappy ol' carlise tires. Think thats the problem? Still I would think even with crappy tires they'd wear more even. I mean I got a 1/4" ledge on the two inside treads on both tires. |
| Author: | BROOKS [ Thu Feb 12, 2009 7:36 pm ] |
| Author: | Pooh Bear [ Thu Feb 12, 2009 7:49 pm ] |
The carlise's have been known to wear uneven.get a better grade trailer tire and you will see the differance. You can maybe contact Jims wheel alighnment,Able spring and alighnment or margot and see what they can do for you. hope this helps. |
| Author: | Kelly [ Thu Feb 12, 2009 8:20 pm ] |
Ok; gonna visit my bro-in-law this weekend in Austin who's a tire rep for some big tire outfit. I'm gonna bring my rims and see if he can fix me up with some quality rubber. Chances are he'll put way more tire on there than what I need, but at least I can cross that off the list. |
| Author: | etquackster [ Fri Feb 13, 2009 8:37 am ] |
carlise trailer tires are blow outs waiting to happen jmo . |
| Author: | Machine [ Sat Feb 14, 2009 12:10 am ] |
put a square up next to em on the flat floor. I had the same thing on one side of my bullet trailer. when the welded the spindles in they just tacked one side and it pulled when they welded it. putting a good set of tires on there is just ruining a good set of tires if it's not square. |
| Author: | D Duck [ Thu Feb 19, 2009 12:09 pm ] |
| Author: | Nab [ Thu Feb 19, 2009 2:58 pm ] |
cutt down nailed it - when it's time to replace just replace with some some radials - they will last 3x's as long and ride alot better too. |
