HuntingRDR
Joined: Thu Jan 15, 2009 4:19 pm Posts: 530 Location: TX
 GTR Trim Help/Updates
I was out running my boat last night and my trim decided to fail as soon as I got back to the ramp. I can hit the up or down switch and you can hear the trim motor working, but nothing is happening. Its not pushing the trim bar out or pulling it in. Motor just sits there. Anyone know what the deal might be? This is my second trim actuator too, and this one probably only has less 50 hours on it. Should still be good. Will call gator tail this week if I can't figure it out.
Also, are there any new updates on the new belt housing boxes and the plastic front switch panel? Last I heard they were making some new ones out of aluminum but haven't heard anything since. Might just be a rumor.
Thanks for the help.
_________________ 1754 GT w/ 35 GTR Hoytafied
| Sat Feb 20, 2010 9:13 pm |
WestEndAngler
MMT Moderator
Joined: Thu Mar 05, 2009 9:11 am Posts: 9143 Location: Houston | Surfside
 Re: GTR Trim Help/Updates
Did you check your connections mine would do the same thing and it was a loose connection. Check that before diving in deeper.
_________________ GTB 1860 w/ 2019 GTR40XD-HO
| Sat Feb 20, 2010 9:22 pm |
HuntingRDR
| Sat Feb 20, 2010 9:49 pm |
WestEndAngler
MMT Moderator
Mine would click and barely work when I had a loose connection..
| Sat Feb 20, 2010 9:54 pm |
HuntingRDR
Mine sounds just like it does when it works. You would not know the motor wasn't going up and down if you were not lookin at the motor when pushing the button. Sounds the exact same as when it was workin...if that makes any sense. But ill check it out tomorrow.
| Sat Feb 20, 2010 9:58 pm |
WestEndAngler
MMT Moderator
| Sat Feb 20, 2010 10:26 pm |
HuntingRDR
| Sat Feb 20, 2010 10:37 pm |
craig
Sounds like you need to add fluid. It's easiest to take the trim unit loose to work on it.
| Sat Feb 20, 2010 10:49 pm |
HuntingRDR
I will add more fluid to it tomorrow. May have a leak. Haven't looked at it too close. If I do have a leak, I will cal gt this week. I'll look more into it tomorrow.
| Sat Feb 20, 2010 10:58 pm |
Gatorpoint
Joined: Tue Jan 13, 2009 8:09 pm Posts: 1175 Location: A slough behind you, TEXAS
Check for a leak coming out around the ram. Hoyt will take care of ya if you have a prob. Good luck.
_________________ 1854 Brotha Breaux Bateau pullin' a 35 GT arrrrahhh! Willett Welding custom boat trailer
| Sat Feb 20, 2010 11:09 pm |
