Full Throttle
Joined: Sun Jan 25, 2009 8:09 pm Posts: 1268 Location: North Texas
 1 or 2 Batteries
I'm trying to cut some weight on my rig and am considering dropping the battery under the front deck and running just 1 for lights and cranking the motor. How are ya'll set up?
_________________ WC Custom 1854
| Tue Dec 15, 2009 3:50 pm |
JBREAUX
Joined: Tue Jan 13, 2009 8:12 pm Posts: 412 Location: soufff la
 Re: 1 or 2 Batteries
I use 1 for everything but I always keep a extra battery with me just incase
| Tue Dec 15, 2009 3:56 pm |
keestan31
Joined: Fri Aug 21, 2009 9:40 am Posts: 1703 Location: Groves, Texas
I only run one battery for cranking and lights. Then have a seperate battery for a trolling motor.
| Tue Dec 15, 2009 3:57 pm |
Full Throttle
| Tue Dec 15, 2009 4:02 pm |
POKER1
I ran 2 lawn tractor batteries for a couple years. 1 on the motor and running lights and 1 up front as a spare and for any additional lights. I have everthing used in the boat on TM plugs. So my spare is hooked up in place of the deep cycle for hunting and swapped out for the deep cycle when using the TM for fishing. Never had a cranking problem with the lawn tractor battery, thats what they are made for. 2 of them probably weighs less than 1 large battery. But I will always have 2 batteries or a jump pack on board to be safe.
| Tue Dec 15, 2009 4:16 pm |
Capt Jeff Kraynik
Joined: Thu Jan 15, 2009 3:48 pm Posts: 102 Location: Florida's Space & Treasure Coasts
If I'm not having to winch over a levee, (1) one dual type cranking/deep cycle works best.
If pulling over, I will temporarly put the 2nd battery in the boat.
_________________ If your courage holds, luck will get you through most situations!!!
| Tue Dec 15, 2009 4:18 pm |
quackconsumer
I run two batteries only because my headlight draws a battery down after only bout 1 1/2 - 2 hrs. and der is no pull start on these things.
| Tue Dec 15, 2009 4:20 pm |
dylndaw
Joined: Sun Feb 08, 2009 3:15 pm Posts: 117 Location: Prairieville,LA.
always carry a spare battery! its sort of like having more clothes on than you need when you go out in the cold,you never can tell if you need what you have once you leave the landing but if you break down, you have it with you....The best way ive found is to start and trim with one battery and run the lights with a smaller battery.the motor (charging rectifyer)can keep up with the starting and the trimming of the motor but the lights have a steady drain.
| Tue Dec 15, 2009 5:15 pm |
dylndaw
hey fullthrottle,what size battery do you have?
| Tue Dec 15, 2009 5:19 pm |
Full Throttle
| Tue Dec 15, 2009 5:37 pm |
dylndaw
I use the medium size interstate cranking battery for the starting and trimming but also carry a small 12volt 12amphour non-spillable maintanance free battery that can actually start the motor if needed.I charge it up every time I get back to ensure its always ready. If you put too much load on your charging system,It could cause the rectifyer or harness to burn-out. between the two batteries its only 21 lbs.
| Tue Dec 15, 2009 5:48 pm |
shallow water master
Joined: Tue Jun 16, 2009 8:27 pm Posts: 1803 Location: Belle Chasse La.
| Tue Dec 15, 2009 5:57 pm |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
I use one battery for the lights and motor but I always carry a back up that I have a spot light hooked to.I really never use the spot light unless I'm frogging but I also use it for the trolling motor when fishing.
| Tue Dec 15, 2009 6:55 pm |
50fps
I run a deep cycle for the TM and one of these http://www.jpcycles.com/search/ProductD ... 0&N=274306 28002800&Ne=28002799&Ntk=All&Ntt=&Ns=DefaultSort&results=10&Nao= for starting and nav lights.
| Tue Dec 15, 2009 7:46 pm |
Matt
Joined: Tue Jan 13, 2009 5:39 pm Posts: 190 Location: Chauvin,La.
How much power does the clutch use?
What does the charging system put out?
| Tue Dec 15, 2009 8:00 pm |
Skipr
Joined: Fri Sep 11, 2009 6:48 pm Posts: 701 Location: Houma, LA
I use one for cranking and a second deep cycle for the trolling motor. I put those removable clamp style nav lights because the only time I run with lights is for hunting season.
| Tue Dec 15, 2009 8:03 pm |
LA Mudder
Joined: Wed Oct 21, 2009 9:18 pm Posts: 422 Location: Belle Chasse, LA
I use 1 battery for everything: running lights, spotlight, motor, and stereo and never had it even feel weak on me.
_________________ 18x58 w/healthy GTR 35 "A good friend will bail you out of jail but a true friend will be sitting by you saying damn that was fun"
| Tue Dec 15, 2009 9:11 pm |
HuntingRDR
Joined: Thu Jan 15, 2009 4:19 pm Posts: 530 Location: TX
_________________ 1754 GT w/ 35 GTR Hoytafied
| Tue Dec 15, 2009 9:12 pm |
coastal
Joined: Wed Jan 14, 2009 8:29 am Posts: 1890 Location: South TX
X3..
_________________ I will keep my gun's,freedom and money.You can keep your change!
| Tue Dec 15, 2009 9:18 pm |
BrackIV
Joined: Sat Nov 21, 2009 8:58 pm Posts: 641 Location: SETX
After having engine troubles one morning, pull rope breaking, lights draining the battery, turning the engine over for 20 seconds at a time just to get it started, drifting in the middle of the intercoastal canal w/ barges full steam ahead in my direction, engine dying every 100 yards and repeating the process of cranking and drifting, a battery flying solo is not the way to go. Never again will there only be one battery in my boat. We made it to our pond some how that morning. BUT, we didnt make it back. We got lucky that someone else decided to hunt that random wednesday morning, and towed us back. Made it to class in time though, barely. God must have been in the boat w/ me. Anyways, NO NO NO NO NO NO to only one battery.
_________________ 1854 InstaGator 35 GTR w/ carb and MM exhaust
"Addicted is an understatement" *GEAUX TIGERS*
| Tue Dec 15, 2009 11:14 pm |
quackconsumer
| Wed Dec 16, 2009 12:14 pm |
idabilly
Joined: Sat Jan 17, 2009 7:17 pm Posts: 617 Location: Idaho
I use one battery and I carry one of those jump packs for backup. I don't run a trolling motor so I have never seen the need for 2 batts. Those things are heavy!
I run twin 130 watt lights on the front of the boat and they draw some current...but I only have them on during my high RPM runs to the spot. I always turn them off when I get there. I never use them while idling around setting dekes. That will run a battery down fast.
| Wed Dec 16, 2009 2:28 pm |
Ace
Joined: Thu Jan 15, 2009 9:26 am Posts: 285 Location: Lafayette LA
2 batteries for sure. Bought a deep cycle from Wal Mart January of this year. November of this year, was dead. Most likely from a lot of idling during frogging and going to the camp. The battery was sure dead. Had a replacement warranty and it did not cost anything, but I use 2 batts. 1 for the motor and nothing else but some small interior lights, 2nd for the TM and accessories, hard hat, etc. Also need to make sure if you idle a lot, then either charge the main battery, or turn some rpm's to recharge. JMO
_________________ Ace Cajun Performance 1854/GTR35 Tiller (Lil Daddy Mods)
| Wed Dec 16, 2009 2:45 pm |
dead animal
get 1 good battery. that's all u need. especially with the newer engines.
carry a spare when froggin or for the trollin motor.
u ain't trying to turnover a big block chevy. u ever seen 2 batteries on a lawnmower?
| Sat Dec 19, 2009 8:18 pm |
Team Camo
| Sat Dec 19, 2009 11:01 pm |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
[quote="dead animal"]get 1 good battery. that's all u need. especially with the newer engines.
u ain't trying to turnover a big block chevy. u ever seen 2 batteries on a lawnmower?[/quote]
No, but if my lawnmower doesn't start I won't freeze or starve to death, or worse yet, get home late on a day I have babysitting duty while the wife goes shopping.
| Sun Dec 20, 2009 2:03 am |
dead animal
if ur motor ain't gonna start, six batteries won't help. i run a 200$ gel fancypants battery. i do check my voltage regulator from time to time to make sure it's putin out and i put the battery on charge every now and then too. stumpy runs a 20$ pissy amp lawnmower battery. he gets by. if ur not froggin or using the battery for anything but the motor, nav lights, and sum hardhat light duty, u brobly don't need two. and if u gots room, and it makes u feel like a boy scout, or if ur scared of ur wife or whatever, then by all means carry 2 batteries!!!! me, i get by with one. unless ithink i need two, then i bring two, unless i think i need three...etc...........
| Sun Dec 20, 2009 9:56 am |
quackconsumer
| Sun Dec 20, 2009 10:03 am |
