It is currently Thu Apr 09, 2026 10:28 pm
Reply to topic  [ 6 posts ]
 Cleaning Carb on PD36?
Post Cleaning Carb on PD36?
did a search here and on Google and couldnt find what I was looking for.
Does any one have best practices for cleaning a carb and jets? Would love to see a step by step if anyone has it.
Thanks,
Tue May 09, 2017 10:17 am
Post Re: Cleaning Carb on PD36?
Remove carb, remove bowl, set gasket aside, remove each jet from the bowl and keep side specific. Spray carb cleaner in each jet orifice in bowl, spray carb cleaner in emulsion tubes, and idle circuit passages in carb, spray carb cleaner in fuel entrance and let run out through needle and seat. Blow compressed air through the same places you sprayed carb cleaner. Clean each jet with a small wire or tip cleaner and clean with carb cleaner and blow out. Install back in bowl, install bowl and gasket onto carb, then install carb onto engine. Run engine.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Tue May 09, 2017 12:06 pm
Thanks Max. I am a little challenged in some areas....... :D
Tue May 09, 2017 12:22 pm
Not a bad job. Ive done it numerous times, But I do kinda work on them for money lol. Its about a 1 hour job for a first timer.
Bayou Surface Drive
337-351-0362
Tue May 09, 2017 12:52 pm
If you gonna tear it all down, might as well soak that bitch for a day or two! Probably has that green funk growing all in it. :lol:
Tue May 09, 2017 1:33 pm
A little Berryman B-12 in the tank helps keep it clean once you get it to that stage also. Under $4 at Walmart.
Tue May 09, 2017 3:22 pm
