It is currently Sun Apr 12, 2026 12:38 pm
Reply to topic  [ 114 posts ]  Go to page 1, 2, 3  Next
 SD build
Post SD build
Figure I would try my hand at building a sd. Going to either put a 6hp or 10hp on it. Probably going to take a while because I'm just working on it little at a time. Everything will be made out of 3/16 5086 alum (all scraps off a boat).
Here's where I am now. I have the belt housing built and part of the transom mount.
Fri Oct 18, 2013 11:08 am
Post Re: SD build
Looks good! Bit of advice even though your just putting a 10hp motor on it if you even decide to go to a bigger hp motor go as thick as possible and main stress points(transom bracket) I've never built one, but I did have a Dixie mm and they went think on aluminum on main stress points and caused me to have tons of problems. Broken welds snapped prices of aluminum.
Fri Oct 18, 2013 2:21 pm
Post Re: SD build
Well I decided to do the pivot points out of some steel hinges I had. I hated to do it like this but I didn't fell like buying 20' of pipe and rod to build a 6" hinge. And I know this will last alot longer than the alum.
Fri Oct 18, 2013 2:41 pm
Post Re: SD build
That's definitely a different way to go about the pivot.
Don't see why it won't work though!
Fri Oct 18, 2013 6:01 pm
Post Re: SD build
lookin good so far.
Fri Oct 18, 2013 6:42 pm
Post Re: SD build
Anyone have an idea on a motor? Want something cheap. I can get a 10hp LCT for around 200 but don't know much about them. I'm building a lt with a 6hp briggs too so I thought about briggs.
Anyone have anything bad to say about LCT?
Fri Oct 18, 2013 8:20 pm
Post Re: SD build
They are built just like a Honda, some people swear by them.
Fri Oct 18, 2013 8:25 pm
Post Re: SD build
Found a predator for 119 but its a 6.5 hp.
Fri Oct 18, 2013 8:43 pm
Post Re: SD build
What size gears you gonna use inside the housing?
Fri Oct 18, 2013 9:30 pm
Post Re: SD build
Fri Oct 18, 2013 9:32 pm
Post Re: SD build
cool project. be sure to keep us posted
Sat Oct 19, 2013 8:12 am
Post Re: SD build
Ended up with 2 LCT 12hp motors fo free dollars and free cents!! And got some pullys too!!
Sent from my beeper.
Mon Oct 21, 2013 4:58 am
Post Re: SD build
A good paint job would make them things look a awful lot like a 10hp!
Mon Oct 21, 2013 11:27 am
Post Re: SD build
The boy I got the motor without a gas tank said it had a little knock in it. Well come to find out the connecting rod bots backed out about a 1/4 in. Messed the crank and the conn rod bearings up pretty good. I guess I will build this one up for higher hp!! Other motor runs great!
Thu Oct 24, 2013 6:30 am
Post Re: SD build
Wow....that was close!
A little nock...lmfao
Thu Oct 24, 2013 6:43 am
Post Re: SD build
You ever prpgressed on this unit?
35 GTR chasin a BBC 1848
Wed Nov 27, 2013 6:22 am
Post SD build
Negative. Put one of the motors on a lt frame I have. Building boats right now so I don't really know when I will be able to get to it.
But I got with my machine shop guy and got the shaft and bearing figured out though.
Thu Nov 28, 2013 7:31 am
Post Re: SD build
Anyone know what prop to run for this little motor? Going to be the same gear ratio as a copperhead. Thought about running a 9x9 or 10x8 hill.
Sent from my beeper
Thu Sep 11, 2014 6:53 am
Post Re: SD build
10x8
Thu Sep 11, 2014 7:48 am
Post Re: SD build
Got the shaft and bearing housing made.
Sent from my beeper
Thu Sep 11, 2014 7:59 am
Post Re: SD build
Gonna cap it off?
Thu Sep 11, 2014 8:23 am
Post Re: SD build
Sent from my beeper
Thu Sep 11, 2014 8:53 am
Post Re: SD build
Time for the bracket?
Thu Sep 11, 2014 9:28 am
Post SD build
Got most of the housing done.
Sent from my beeper
Thu Sep 11, 2014 2:53 pm
Post Re: SD build
U bored today? Comin along!! What u gonna put it on? The midget?
Thu Sep 11, 2014 3:05 pm
Post Re: SD build
Thu Sep 11, 2014 3:46 pm
Post Re: SD build
so there will be no bearings in the front side?
Thu Sep 11, 2014 5:28 pm
Post Re: SD build
Looks good! how are you planning on sealing the front?
1850 Uncle J
Delta Performance level 4 GTR
Thu Sep 11, 2014 6:34 pm
Post Re: SD build
Thu Sep 11, 2014 8:07 pm
Post Re: SD build
Fri Sep 12, 2014 11:17 am
Post Re: SD build
Its getting there!
1748 Cottonmouth Hybrid Custom with a 2015 35GTR
7 yr old Boykin Spaniel
One Badazz wife that that hunts like a champ
ROLL TIDE!!
Fri Sep 12, 2014 11:56 am
Post Re: SD build
Looking good N La Hunter. What boat you plan on building for your SD build?
18x48 GDSD boat
Fri Sep 12, 2014 3:22 pm
Post Re: SD build
Fri Sep 12, 2014 4:02 pm
Post Re: SD build
I have a question about the skeg.
Shouldn't it be the same distance from the shaft that the prop is or a inch or 2 bigger?
As in the prop is 10" so the tip of the skeg will be 5" from center of the shaft?
Sent from my beeper
Mon Sep 15, 2014 6:43 am
Post Re: SD build
Mon Sep 15, 2014 7:32 am
Post Re: SD build
Got the skeg and motor mount on.
Sent from my beeper
Mon Sep 15, 2014 4:39 pm
Post Re: SD build
That thing is looking pretty good man
Mon Sep 15, 2014 5:28 pm
Post Re: SD build
NLH Mud Motor's
Mon Sep 15, 2014 5:33 pm
Post Re: SD build
Looks good
18x40 skiff/35 hp GTR
Post SD build
Mon Sep 15, 2014 5:35 pm
