It is currently Wed Apr 24, 2024 3:04 pm
[ 4 posts ] |
Removing small amounts of contact cement
bluesky2012
I had a little bit of contact cement creep out in a fe spots around edges during my hydroturf install. Is there a good way to clean that off? Heat?
Tue Jul 18, 2017 7:14 pm |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
Re: Removing small amounts of contact cement
Pocket knife works pretty good. But I don't think there's is any good way to remove it without taking the paint with it.
Tue Jul 18, 2017 8:05 pm |
45th parallel
3M citrus base adhesive remover is the safest with paint and foam, lacquer thinner will do it too, but will dissolve your paint and melt your foam if you spill any or rub it.
_________________ 35 Swomp on a 17-52 Alweld on a crusty old trailer you probably shouldn't follow too close 10hp Swomp lite 14-36 alumacraft
Mon Jul 24, 2017 3:56 pm |
bluesky2012
Ended up using a little goo gone and a toothbrush and got it up fine. I appreciate the input. Used WD40 on a big test spot away from the hydroturf and it came off well with it too. The contact cement had only been on for a day, not sure if it makes a difference but the final product came out well in my opinion.
Mon Jul 24, 2017 5:36 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 278 guests |
