It is currently Thu Apr 02, 2026 3:49 pm
Reply to topic  [ 12 posts ]
 27 hp prodrive
Post 27 hp prodrive
So guys got a lil issue. I have a 27hp pro drive did a kawasaki swap on it motor runs flawless only problem is that i cannot get speed. Its on a 18x36 skiff. I have a 24 honda longtail i used to have on it goes 20mph with it...... any ideas i wanna say prop is wrong size. It was a 32 generac used to be on it..
Sat Sep 23, 2017 7:11 pm
Post Re: 27 hp prodrive
you put a big block kawa on it? what is the current diameter of your prop? how many rpms are you turning at what speed. all of this info will help with troubleshooting.
#TheGhostBoat
Sat Sep 23, 2017 8:12 pm
I put the fx751v prop is pretty worn down and im tryina get a tiny tach right now
Sun Sep 24, 2017 5:45 am
If you put a FX921V or FX1000V, you need a 12-12.5" diameter prop at minimum. Depending on your setup, these engines have lots of torque.
Mon Sep 25, 2017 4:54 am
banded i put the 27hp kawasaki on it.
Mon Sep 25, 2017 6:44 am
What are your rpms?
Mon Sep 25, 2017 6:57 am
no clue trying to get tach.
Mon Sep 25, 2017 8:15 am
Mon Sep 25, 2017 9:03 am
Its gonna be trial and error. And it won't compare to the BIG block kawis due to the fact it has a different head design than ours. We have a 6 valve arrangement, yours is 4. Any performance items you do, cam, minkui or EFI, will also be trial and error. You'll have to make most of your parts the same way we did.
Mon Sep 25, 2017 12:04 pm
i dont plan on doing performance more of the reliability part of the kawasaki's
Mon Sep 25, 2017 2:31 pm
What was wrong with the Generac?
Tue Sep 26, 2017 5:48 am
block cracked in 4 different spots and welded a piston into the side of the block.
Tue Sep 26, 2017 7:15 am
