It is currently Thu Nov 05, 2026 7:36 am
Reply to topic  [ 16 posts ]
 gt replacement trim
Post gt replacement trim
Got the new gt replacement trim. Installed it works great. But when trim is going down it makes a squealing
noise. I backed all bolts off a little to make sure they where not to tight and it still dose it. Any ideas? Thanks
Fri Mar 01, 2013 7:18 pm
Post Re: gt replacement trim
It's too g to clear up
Fri Mar 01, 2013 7:23 pm
it's too g to clear up?.........did u mean it will clear up?
Fri Mar 01, 2013 7:29 pm
HOTSAUCE170 wrote:
Fri Mar 01, 2013 7:40 pm
I have the 2013 trim and it noisy but still works
Fri Mar 01, 2013 7:46 pm
Been like that since day 1
thanks, will call gt monday just so they will know. i'll run it till then trim has a one year warranty. other than noise it seems to respond better than the old style trim.
Fri Mar 01, 2013 7:54 pm
Is the amount of trim the same on the new and old trim units ? Not that it matters was just qurious
EMF 16x42, 3/16 skiff, 35 GTR Stage 0
Fri Mar 01, 2013 8:03 pm
yes it is i marked it and trims just as much. when ordering they ask if u got 23 or 35hp. the differents is the piovit block that mounts on front side of trim.
Fri Mar 01, 2013 8:08 pm
Some squeal on way down. Just keep working it & it'll stop eventually. It's just a lil air pocket causing the squeal and will work itself out.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Mar 01, 2013 8:10 pm
thanks for all the posts. i will run it a bit. and then give a update. i thought that, that it was air in it.
Fri Mar 01, 2013 8:18 pm
8-) I might've had 1 or 2 or 3 or... :lol:
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Mar 01, 2013 8:28 pm
Yes auto type. It should clear up. Mine did when I had it
Fri Mar 01, 2013 8:36 pm
Just bought one a couple months ago and it did it at first but cleared right up!
1746 GTB 35 GTR
REFRIGERATOR STAY EMPTY CAUSE I EAT GOOD
Fri Mar 01, 2013 8:44 pm
Mine does the same.
Sat Mar 02, 2013 11:22 am
I know this is old but I got the new style GT trim unit 3-4 years ago and it squeals on trim down but not on trim up. I thought it would go away but it never did. It still squeals on trim down if it has been sitting on trim up for a while with the motor level. If I let it sit trimmed down for a while it won't squeal at all. It has to have air in the fluid. Do others still have units that squeal on trim down? Anybody know a fix like adding fluid or trying to bleed out air?
Sun Mar 04, 2018 7:56 am
