It is currently Fri Feb 20, 2026 1:29 pm
Reply to topic  [ 25 posts ]
 FNR GD
Post FNR GD
Anyone bought one or ran one yet?
Mon Apr 16, 2018 9:23 am
Post Re: FNR GD
Mon Apr 16, 2018 10:21 am
Post Re: FNR GD
Pricing seems comparable with the 40hp head, $200 less than a GTR. I haven't seen a published price on the HDR to compare to yet.
I'll stick with FPR, but if your a frogger or someone who doesn't know how to launch a boat the others work good also.
Tue Apr 17, 2018 8:18 am
Post Re: FNR GD
Tue Apr 17, 2018 11:53 am
Post Re: FNR GD
I heard from a reliable source that there easier to drive than the old forward all the time ones !
Tue Apr 17, 2018 12:41 pm
Post Re: FNR GD
Tue Apr 17, 2018 12:47 pm
Post Re: FNR GD
Tue Apr 17, 2018 3:44 pm
Post Re: FNR GD
https://www.louisianasportsman.com/lpca ... &id=859415
Tue Apr 17, 2018 8:13 pm
Post Re: FNR GD
That lower housing is still going to get caught on every f’n piece of a floating mat. That said, I’m more than pleased with mine after what I’ve put it through the years.
1654 Grizzly
'13 35 GDSD
- My Wife
Tue Apr 17, 2018 9:57 pm
Post Re: FNR GD
Wed Apr 18, 2018 5:26 am
Post Re: FNR GD
I don’t understand why anyone would say the price is terrible. It’s the cheapest priced surface drive with neutral and reverse.
40HP Gatortail
Thu May 10, 2018 7:22 pm
Post Re: FNR GD
A buddy bought one and says it I’ll drive farther and back harder than any other horizontal engine. We are going to see on 6/9 he wanted to put together a mud ride to see who can dig better.
Fri May 11, 2018 7:30 am
Post Re: FNR GD
Sat May 12, 2018 8:09 am
Post Re: FNR GD
Definitely past due!
Tue May 29, 2018 9:22 am
Post Re: FNR GD
when the 23hp one comes out I might have to upgrade from my longtail. Should haul ass on my 1638
1638GD with 23GDLT
542 war eagle with 25 yamaha
A few pirogues
Thu May 31, 2018 7:50 am
Post Re: FNR GD
Drove the 40 GD FNR - today....
Impressive - especially the 40 Briggs powerplant.....
Thu May 31, 2018 7:47 pm
Post Re: FNR GD
Thu May 31, 2018 7:49 pm
Post Re: FNR GD
So briggs did what we have been doing for years and its the BEST thing lol.. More compression, better camshaft, and better exhaust...
Fri Jun 01, 2018 5:20 am
Post Re: FNR GD
Fri Jun 01, 2018 7:46 pm
Post Re: FNR GD
*facepalm* new metal types, eh?
#TheGhostBoat
Fri Jun 01, 2018 8:30 pm
Post Re: FNR GD
Sat Jun 02, 2018 6:06 am
Post Re: FNR GD
Sun Jun 03, 2018 1:23 pm
Post Re: FNR GD
Reverse is very functional... I went to one of my hunting ponds and used FNR
as if I were retrieving decoys and found it comparable to outboard on jackplate...
However with an angled shaft it tends to splash in over the transom a bit if
you throttle up excessively.... I never had a splashover and by pushing tiller
to far port side could romp the throttle pretty hard without splashover...
But I have seen GTR users with similar washovers and even cover themselves
in mud with full power digging... I would expect the same from the FNR or any
reverse enabled MM...
I was testing on my favorite hull the GD 1844 --- would be intersted myself to
see it on the newest GD hunt deck hulls... Maybe next test drive ! ! !
They are bringing some hunt decked hulls to the Houston boat show June 13-17
maybe who ever buys one will want to go riding afterward ???
Sun Jun 03, 2018 8:08 pm
Post Re: FNR GD
A forged rod, piston with less dish for more compression, different camshaft, supposedly better block casting, a different tune, and a better exhaust. Yes its a mildly modified big block that falls within the emissions constraints.
The efi's have variable ignition timing, that in itself is a power difference vs a fixed timing system like the non CDI. The cdi has built in advance, But its quickly to full advance right when you advance the throttle.
the 40 will be an nice setup for guys who want to stay stock. I really want to see how well the heads/seat issue is fixed... 20-30 hours every briggs has daylight around the valve seats
Mon Jun 04, 2018 1:39 pm
Post Re: FNR GD
Not a motor guru - thanks for the details...
Just know that comparing the 40 to the 35 is
like comparing the 35 to the 23 !
It feels more like 50 hp once it winds up into 3000 plus rpm range...
The dead start holeshot and off idle power and torque are better
than the 35 but not as impressive as that mid range power....
Cause you want smoothness running a twisting bayou or making
hard turns where you need to lay down power more precisely in
the shallows....
The 40 GD FNR delivers all that !
Mon Jun 04, 2018 7:28 pm
