It is currently Fri Feb 20, 2026 9:46 pm
[ 5 posts ] |
pamlico pintail
 Mudbuddy bogging down?
got an 08 mudbuddy recently changed carb. runs about 43 4400 rpm out the water. belt tension is good and looks in good shape. idles fine when in water and runs good till you get up to about 2800 rpm then seems to bog down. also have a new prop. only thing i havnt got around to is changing muffler is it possible i got compression problems from a bad muffler?
| Tue Jun 05, 2018 11:47 am |
Bigbend
Joined: Sat Dec 11, 2010 6:25 am Posts: 493 Location: SWGA
 Re: Mudbuddy bogging down?
Is your gas tank properly vented, all your fuel connections tight?
| Tue Jun 05, 2018 12:22 pm |
Buzz Killington
Valves good? Coils too?
Support your troops. We support you.
B.
B. MacDonald
| Tue Jun 05, 2018 12:43 pm |
pamlico pintail
no vent in gas cap going to replace and try to run this weekend. hopefully it will be that simple of a fix. thanks
| Thu Jun 07, 2018 5:12 am |
Russ
Just loosen the lid until you identify it's the problem.
| Thu Jun 07, 2018 5:23 am |
[ 5 posts ] |
