km
Joined: Tue Aug 25, 2009 12:26 pm Posts: 17 Location: Erath, LA
 35 GTR Power Trim
Took my boat out for a ride yesterday and on the way in my power trim stopped working. I am getting nothing when I press the up and down button. This motor only has 40 hours on it, anyone have any idea what the problem might be? Going to bring it in to Gator Tail on Monday.
_________________ 17 x 54 GTB w/35GTR
| Sat Jan 23, 2010 8:40 pm |
b_coonass
Joined: Thu Mar 26, 2009 2:08 pm Posts: 1229 Location: morgan city, louisiana
 Re: 35 GTR Power Trim
_________________ 36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
| Sat Jan 23, 2010 9:06 pm |
WestEndAngler
MMT Moderator
The wires came off the back of the switch underneath the trim forward / start cover...?
| Sat Jan 23, 2010 9:26 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
If your wires are good check the fuse. If it's a tiller model the fuse will be located on the port (left) side of the engine when looking from the back of the boat.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
| Sat Jan 23, 2010 10:06 pm |
dead animal
| Sun Jan 24, 2010 8:49 pm |
cmelvin
Joined: Fri Nov 13, 2009 8:47 pm Posts: 1039 Location: Texas
i had this same problem happen to me once. the ground wire had became loose so i tightin it back down and had no problems since
_________________ To be successful, you must decide exactly what you want to accomplish, then resolve to pay the price to get it.
| Sun Jan 24, 2010 9:57 pm |
keestan31
Joined: Fri Aug 21, 2009 9:40 am Posts: 1703 Location: Groves, Texas
| Mon Jan 25, 2010 8:36 am |
BROOKS
Joined: Tue Jan 13, 2009 9:46 pm Posts: 4596 Location: East TEXAN Proud
Thay was puttin' a fuse/breaker that looks kind of recktangled on the port side of engine rite by the wirin' harness ..... it be havin' a reset button on it .... mash it and see what you gots.
_________________ Git a Gator-Tail or ride in mines wake ...... MtrFact !!!!! '05 Model .... Still Number One on the Water !!!!
| Mon Jan 25, 2010 9:27 am |
MaXXis85
My trim has not worked a few times. Everytime it has been a loose connection at my battery. Things loosen up with the vibs. If you have relays in the battery box check to make sure they are good, because they are for the Trim.
| Mon Jan 25, 2010 9:41 am |
quackconsumer
Check your connections at da switch and at da battery. Also check da fuse and try da reset button. If it still don't work check your relays by by-passing da power straight to your trim motor. If you still don't have anything bring to GT I had da motor for my hydrolic trim go out on me once and they replaced my trim in about 20 minutes.
| Mon Jan 25, 2010 11:22 am |
km
Thanks for all of the responses. I will check it out when I get back home on Thursday.
| Tue Jan 26, 2010 7:16 am |
km
Traced the wire back to a little box that was hanging by a wire. The nut had fallen off. Put a locknut on it so that dosent happen again.
Thanks for all of your responses.
| Mon Feb 08, 2010 12:30 pm |
