It is currently Thu Apr 09, 2026 12:49 am
[ 5 posts ] |
Sambeaux2003
 Buying a new, used rig
What are some of the things that someone should look for when they are looking at a used boat and motor, other than the obvious.... Are there certain things one should look for.
| Wed Mar 03, 2010 9:10 pm |
OwenDickeson
 Re: Buying a new, used rig
depends on what you want and how much ur lookin to spend.
| Wed Mar 03, 2010 9:15 pm |
dpd
Joined: Thu May 07, 2009 10:25 am Posts: 714 Location: Thibodaux, LA
I think I understand your question, but if I go off on a tangent...sorry.
1) Since you are buying a mudboat, make sure the bottom isnt hooked to hell.Lookat it and see. Put a string on it to tell the tale. 2) Consider the overall condition of the hull, looking for cracks or leaks. 3) Consider the overall appearance of the boat and motor(some people including myself put alot of emphasis on this. They also look at how the person keeps up other shit around their house or shop) 4) how many hours does the motor have....big guess, his word only 5) Find somebody you can trust that knows the history of the boat and motor if possible 6) Research the boat builder 7) ask for a test ride, if that isn't availabe get in your truck and go home
That's a pretty good start. Everybody else can add to it.
_________________ 16 x 48 Blanchard Bateau / 40 PD FPR Eat,Sleep, Fish, Hunt. Repeat.
| Wed Mar 03, 2010 9:23 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
On the hull I always check the welds, and look for spots that have been repaired. Fiberglass hulls I'd check for soft spots and cracks.
On outboards I always pull the cowling and look for oil and residue in the bottom. Check to see that it goes into & out of gear easily and fully engages. Check for a bent shaft, and for water in the lower unit.
On a MM, check the oil for deposits. Check for bent shaft, all the obvious stuff like wiring, plugs, carb trouble, etc.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
| Wed Mar 03, 2010 9:34 pm |
Sambeaux2003
That's what I was lookin for.... Thank yall for the help
| Thu Mar 04, 2010 9:48 pm |
[ 5 posts ] |
