| GTR Idle speed http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=2&t=8225 |
| Author: | Tenpoint [ Thu Mar 04, 2010 7:23 pm ] |
| Post subject: | GTR Idle speed |
What is a good average idle rpm for the 35. Mine tends to speed up gradually while in neutral. It will get up to 1400 rpm sometimes. I bump the throttle and it will drop to about 930. Thats about where Id like it to stay but it slowly speeds back up. Just curious. |
| Author: | craig [ Thu Mar 04, 2010 7:28 pm ] |
| Post subject: | Re: GTR Idle speed |
1100-1200 should be good. |
| Author: | Tenpoint [ Thu Mar 04, 2010 7:33 pm ] |
| Author: | DMC [ Thu Mar 04, 2010 8:41 pm ] |
Mine idles around 750-800 in gear with stock carb. Around 1000 in neutral. |
| Author: | MaXXis85 [ Thu Mar 04, 2010 9:14 pm ] |
Mine used to do that until I lowered the idle speed to 1150 and made sure my governer was set to 4250 then it idled great and consistant. Beofre the adjustments it would idle erraticly |
| Author: | Tenpoint [ Fri Mar 05, 2010 6:46 pm ] |
| Author: | DMC [ Fri Mar 05, 2010 8:19 pm ] |
| Author: | deltaduckmaster [ Fri Mar 05, 2010 8:27 pm ] |
Ok set the gov. at what ever you wont wfo ou the water i say 4200 is good.. After you got that bend this little arm with the spring to get your idel perfect!! Fork the idel screw!! |
| Author: | deltaduckmaster [ Fri Mar 05, 2010 8:31 pm ] |
Ten i had to seach trough about 5 years worth of pics on my photobucket to find that pic so use it !! |
| Author: | Tenpoint [ Sat Mar 06, 2010 7:10 am ] |
