It is currently Fri Mar 27, 2026 4:25 am
Reply to topic  [ 1379 posts ]  Go to page Previous  1 ... 28, 29, 30, 31, 32, 33, 34, 35  Next
 Kawi FXT00V "Let the good times roll"
Post Re: Kawi FXT00V "Let the good times roll"
The stock springs were measured on two different engines. I was there when the 4 springs were measured. The century springs that I have are 30 lb springs. They do make a smaller diameter spring ghat is smaller than stock, but it's only 24 lbs. I'm sure you can get some custom made but $$$ might be too much. Mine measured 15 and 18 on 1 head. I know mine floated with the stock springs and 310 +4. You could hear it. I just kept it under 4500 until I got the century springs that I'm running now.
Wed Jul 08, 2015 2:56 pm
Wed Jul 08, 2015 3:24 pm
I will add, I would like to not see valve float happen until over 5000 rpms. I wont run that hard, but it would be nice to have a buffer...
Wed Jul 08, 2015 3:25 pm
Wed Jul 08, 2015 3:48 pm
Used this
Wed Jul 08, 2015 3:57 pm
Interesting. I thought at one point you said the century spring were still floating. What size shim are you using if any?
As soon as I get information from this spring guy, I will post it. He seemed interested in what we were doing and eager to help...
Wed Jul 08, 2015 4:08 pm
Wed Jul 08, 2015 4:29 pm
10-4.
One thing I noticed about the stock springs is that the coating is coming off just from handling them. I will be anxious to see what this spring company has to say.
Wed Jul 08, 2015 6:14 pm
Yeah, half of mine came off also before I swapped.
Wed Jul 08, 2015 7:10 pm
Weeeelp. Got the modified pushrods and carb installed today.
Muffler should be completed by Tuesday. Going to do a bit of carb tuning and try to get her in the water next weekend.
Fri Jul 24, 2015 4:41 pm
Damn, went polished carb? Looks good.
Fri Jul 24, 2015 5:13 pm
Ain't the Kawi pushrods the shiz?!?! None of that wondering if they're in the lifter stem BS! Looks good man.
PRODRIVE 1860 CC
Fri Jul 24, 2015 6:41 pm
Polished carb lol. I bought it on ebay. Not sure if it was a Mikuni screw up or the seller. The box had the un polished part number, but that carb was in it. But for the price, I didnt complain.
The fact that you can see the lifter stem is nice. I actually found some of the old aluminum rods and cut them down. Makes the geometry much closer to stock...
Sat Jul 25, 2015 8:04 am
How yall doing with cams any news or break throughs what's the newest grind how is it running
Sat Jul 25, 2015 8:12 am
I know Lee is waiting g on a new grind. Waiting to see how it does before I decide to possibly make a change. But also working on an advancement timing key. Been out of commission with my hand surgery.
Sat Jul 25, 2015 12:32 pm
Im pondering on what to do with mine. I am going to try out the .310 and the stocker.
Wait and see what I think between the two then have the .310 reground to what I decide on. May see how Lee's new grind performs and try something similar but mew to see what results I get...
Sat Jul 25, 2015 1:53 pm
I should know what grind is gonna go on my billet by next weekend! It's close, REAL close...
PRODRIVE 1860 CC
Sat Jul 25, 2015 5:31 pm
Yep I would deffinantly recomend a billet welded hollow cams are a time bomb in my opion
Sat Jul 25, 2015 5:36 pm
This may be more of a general question... But. I fired up the Kawi for the first time. After messing with air fuel and idle for a few minutes i got it idling smooth.
I was looking around at it and when putting my hand under the heads, cylinder #1's exhaust is noticeably hotter than #2. What should I be checking?
Sun Jul 26, 2015 11:32 am
Check your jetting you may be running lean
Sun Jul 26, 2015 11:44 am
I havent even gotten that far. Have not even given it throttle yet. Just idling. Its almost acting as though #2 is not firing, but I just check spark and it looks good.
I can see a small amount of flame out of the number 1 exhaust, but the number 2 is clear... I will check a few other things, but I am not at a point that I am ready to check for lean/rich conditions...
Sun Jul 26, 2015 12:00 pm
Check for spark and check intake gaskets for leaks
Sent from denda this
Sun Jul 26, 2015 1:49 pm
Definitely sounds more like a misfire to me, sorta sounds normal idling and unloaded accelerating. The steel cowling can pinch the kill (ground) wire pretty easy when it's replaced. I did it once...
PRODRIVE 1860 CC
Sun Jul 26, 2015 2:31 pm
Sun Jul 26, 2015 8:55 pm
Trying to understand the train of thought here...
With one carb, spliting into the intake, why would ine cylinder be lean?
Sun Jul 26, 2015 9:02 pm
Post Kawi FXT00V "Let the good times roll"
Sun Jul 26, 2015 9:05 pm
Sun Jul 26, 2015 9:10 pm
Like Todd said your air fuel mixture if off it will run on one cylinder cause the other isn't getting proper air fuel mixture (lean on one side )
Mon Jul 27, 2015 6:41 am
Mon Jul 27, 2015 12:06 pm
So th problem end up being that the coil for cylinder 2 was not close enough to the flywheel and wasn't firing all of the time. It is now so all seems well.
I am still trying to figure out which way to go with the tuning.
The Mikuni manual states the following.
NOTE:
1. If the best idle is achieved with the air screw less than one turn out, the pilot jet is too small and should be exchanged for a larger one.
2. If the engine speed does not slow after two-and-a-half turns out, the pilot jet is too large and should be exchanged for a smaller one.
Both of these are kind of true. With the idle screw more than half a turn out, it seems to be fine. There is a change if it goes in to a wuarter turn. If it is 4 turns out, it starts bouncing a little. I would think the pilot is ok...
I did want to ask, has anyone measure the head temperature at idle? I may just be over cautious, but the valve cover seem hot.
Mon Jul 27, 2015 5:37 pm
With no load you can set idle a little on the lean side. That is if it runs well there...
Mines idled great at 14.5:1 at 800rpm in gear.
Mon Jul 27, 2015 6:30 pm
I have measured temp but only with an iR gun. Not a very accurate way to tell, but all was ok. Even running hard the sump, and oil cooler would only reach about 195. Keep in mind, that's external temps. Internal will be a little higher.
Mon Jul 27, 2015 6:33 pm
Mon Jul 27, 2015 6:38 pm
Mon Jul 27, 2015 6:54 pm
PRODRIVE 1860 CC
Mon Jul 27, 2015 7:45 pm
There is a good reason I am not an electrician. ...
Can anyone tell me where the green and black wires are supposed to go? They come with a small white connector.
I am assumining this is why my chargin system is not working.
EDIT...
I figured out that the wires in question were for the carb solenoid.
The new question is can they be removed...?
Thu Jul 30, 2015 5:49 pm
Just caught your post... Your gonna need the black one! Haha, that's your kill wire as you know now. The green fuel solenoid can be removed. ;)
PRODRIVE 1860 CC
Fri Jul 31, 2015 3:21 pm
Wierd. I dont have either of them hook up but it still kills with the key. The black wire I am referring to is only about 6" longs with a ring connector on it like it is supposed to be the ground for the solenoid...Its only connected to the plug that hooked into the solenoid.
I just noticed that my rectifier was not tightened down so that may be my problem with the charging system. I am assuming it grounds through the mounting flanges.
I am going to rob the tiny tach off of my briggs because the new one has not come in yet. When I put it on tomorrow, I will check to make sure it is charging. If so, its off for a test run on Sunday...:-)
Fri Jul 31, 2015 3:38 pm
viewtopic.php?f=61&t=62975
It is tempting to buy this and put my Kawasaki on it. :lol: :lol: :lol:
Fri Jul 31, 2015 3:58 pm
Do it
Sent from my XT1254 using Tapatalk
Fri Jul 31, 2015 4:25 pm
