It is currently Thu May 15, 2025 4:17 pm
Reply to topic  [ 70 posts ]  Go to page Previous  1, 2
 STILL dies under load...
Post Re: STILL dies under load...
Main reason I went in the carb was just hoping to find something with some trash in it. I agree, it's been running fine as it, why even back with the carb float? It's worked fine for literally years where it's at.
What crack are you talking about??? I haven't replaced the fuel cap no. I did run it with the line directly submerged in the gas in the tank though. That would rule out a bad cap, vent, tank fitting etc...
Thu Jan 23, 2014 7:13 am
Let me know when u remove the bulb. If that's not it, check the intake gasket. Does it or has it backfired?
Thu Jan 23, 2014 7:26 am
Only time it will backfire thru the carb is if it's stone cold and you pin the throttle off idle... I've always had to let this thing warm up for a couple minutes before just taking off.
I've checked the intake and carb gaskets by spraying carb cleaner around them with it running. If they were leaking it would have shown up then I'd think. We're supposed to be getting some real screwed up weather the next few days and who knows what my work schedule will look like. Hopefully I'll have time to throw a piece of hose straight from the pump to the tank and eliminate the bulb and filter connections some time in the next couple days.
Not super motivated to get out in the shit weather and fix this thing to try to salvage an already less than stellar season... It will get fixed though.
Thu Jan 23, 2014 9:20 am
I hope you get that thing sorted out before the big run in a few weeks.....
Thu Jan 23, 2014 9:46 am
Shit, you and me both.... Been fighting this thing for a month. It's getting pretty old lol
Thu Jan 23, 2014 10:39 am
Thu Jan 23, 2014 12:33 pm
I was stuck in fuel tank mode, sorry.
I replaced that thing and chunked the old one. Fixed that leak and now thats good to go. Didn't fix my fuel problem like I had hoped but it wasn't helping either...
Thu Jan 23, 2014 12:45 pm
I had a similar problem- I had to replace my fuel bulb 4 times - they all had minor issues with them.
Finally got a working one and it ran like a top.
Every thing you said above screams fuel system. Not carb, not spark, not timing..... fuel.
Brandon M.
KCCO
Fri Jan 24, 2014 5:48 am
reviving this thread.... shits still broke.
I've adjusted the float and it seemed to have helped but if I go any more it pukes fuel out of the carb vent. I have also taken the fuel primer bulb and fuel filter out of the equation completely.
That being said, those who do run electric fuel pumps, what do you run? If I do this, I'll go ahead and move the tank to the front to justify it I guess.
Mon Feb 10, 2014 9:48 pm
Any input on a pump and maybe where to get one?
Trying to get one on it by the weekend
Tue Feb 11, 2014 8:00 am
Adjusted oil level per the BoatDR's recommendation. it was previously right at the full mark, I lowerd it to right above 'add'. Went and ran it and did not fix the issue but I'm sure it didnt hurt. He suggested the oil could be slinging into the fuel pump pulsation line at higher RPM's causing a restriction in Vacuum supply and ultimately, fuel starvation at higher RPM.
I did manage to get a video of it acting up, Its on my phone. Not sure how to transfer it so it can be viewed here though. If anyone smarter than me wants to see it I'll gladly send it to you :lol:
any more guesses? I'm running out of ideas and time to get it fixed.
Tue Feb 11, 2014 8:32 pm
Does it have a fuel shutdown silonid ? Could be the problem.
Wed Feb 12, 2014 2:01 pm
Read the thread.... Already snipped the plunger off, eliminated that
Wed Feb 12, 2014 3:01 pm
Is the pulse pump mounted to the crankcase?
Wed Feb 12, 2014 6:53 pm
Man I feel bad for you
Frustrating stuff. ...
B. MacDonald
Wed Feb 12, 2014 8:21 pm
So if you take a new bare fuel line with nothing on it and run it from you fuel pump into a gas can and the line coming out of the pump to the carb will it run like normal?
Wed Feb 12, 2014 9:12 pm
I have NOT taken a solid one piece of hose from the pump to the tank. I have removed the filter and bulb and slid in some solid pieces of stainless tubing that were snug in the line and then put clamps on that. It'll hold compressed air, I don't see how that could be leaking.
The pump is not mounted on the crank case. It's mounted on a bracket behind the cowling. There's a small pulsation/vacuum hose coming from the engine to the pump then the inlet and outlet of the pump itself. All of which have been changed.
Wed Feb 12, 2014 11:06 pm
Added a pump, ran like an animal all day... Put about 6hard hrs on it and never an issue with it running... I'd say that fixed it!!!
Sun Feb 16, 2014 9:03 am
Sun Feb 16, 2014 9:34 am
Yep, tried lowering the oil level to just above 'add' and it made no difference. Sprayed the pulse line clean with carb cleaner to make sure nothing residual was left behind. Still didn't work.
I don't know if it's coincidental or not but 3 of us at the mud run yesterday had experienced this identical issue after putting sea foam in the fuel. I don't know if there's anything to that but it was kinda odd.
My pump is Afro-rigged in the boat but it worked like a champ yesterday, all day. I'll do a more permanent install and wire it in now that I know that's the fix.
Sun Feb 16, 2014 9:46 am
What pump did you get? I got the facet pump and it was too much pressure. I put an adjustable regulator set to 3 psi after the pump and it works perfectly.
Sun Feb 16, 2014 10:11 am
It's a Mr Gasket pump that I picked up from Advance Auto. It's 2-3.5psi and only draws 2amps. Comes with a pre filter that installs on the pump also. It was about $45. Worked great with no regulator. My 5/16 lines fit perfectly on the fittings that came on the pump.
Sun Feb 16, 2014 10:21 am
Sun Feb 16, 2014 10:39 am
Well that's good to know.
I'll pick up a spare and throw in the box so it'll be a 1:1 swap if it ever does take a dump on me. If I have to use the backup, I'll get a facet pump for it. Some of the places I run are waaaay waaaay off in the woods. Getting stranded back there would be no bueno.
Sun Feb 16, 2014 10:47 am
Post STILL dies under load...
I went through two facets in two weeks both burnt up I heard the facet was better but they were out at the time I bought a mr gasket to get by until the new facet came in and still haven't had a problem with it yet 4 months now but I have the facet in my boat for a spare
Sun Feb 16, 2014 3:04 pm
I had a mr. gasket on my last boat and never had any issues with it at all. Have the facet on my boat now, haven't had any real problems with it, but it's noisy as fuck.
Sun Feb 16, 2014 3:21 pm
Sun Feb 16, 2014 3:37 pm
X2 mr gasket quiet :)
Sun Feb 16, 2014 5:19 pm
Part no.?
Sent from my iPhone using Tapatalk -
Sun Feb 16, 2014 5:39 pm
http://www.amazon.com/gp/aw/d/B000BWE4RC
This is the one... Time will tell how it holds up but it worked perfectly for the 5ish hours of run time it's got on it so far.
Sun Feb 16, 2014 6:40 pm
Users browsing this forum: No registered users and 209 guests
