It is currently Wed Dec 17, 2025 6:28 pm
Reply to topic  [ 78 posts ]  Go to page Previous  1, 2
 Yet another case gasket leak! Any ideas
Post Re: Yet another case gasket leak! Any ideas
And making a vertical into a horizontal block is easy
Wed Feb 03, 2016 10:21 am
Wed Feb 03, 2016 1:39 pm
It is actually. He wasn't joking.
Wed Feb 03, 2016 4:21 pm
It was a necessity, was quite simple, and is working fine. Thanks again, clay
Wed Feb 03, 2016 4:29 pm
Wed Feb 03, 2016 6:26 pm
Since 2008+ its been a weird road from Briggs. Chinese vs. Japanese products.
Thu Feb 04, 2016 8:19 am
Was the crankcase cover cracking an issue on the non cdi motors?
Mon Feb 15, 2016 6:55 pm
If the motor was made by briggs and stratton, yes.
Mon Feb 15, 2016 8:21 pm
I bought a block for 500 Less than a year ago.
Mon Feb 15, 2016 8:32 pm
I have done away with the gasket and have 20 hours and so far so good. Usually by 20 hours I would have the tell tell signs that the oil was working by the gasket.
1864 4man hide minus the hide, 5500 mudbuddy, 32 inches, my version of a hammer, Wolfmans muffler with underwater silencer.
Mon Feb 15, 2016 9:48 pm
What about pitting around the oil ports from the old gasket?
How is that dealt with?
Tue Feb 16, 2016 2:19 pm
that's old gasket material. I use light emory cloth, and scotch brite pads to clean the areas up.
Tue Feb 16, 2016 2:40 pm
Tue Feb 16, 2016 2:55 pm
I used a wire brush lightly and then emory cloth, then wiped with acetone. I did see some pits afterwards but I used yamabond with the gasket so I magine that will fill the tiny pits nicely enough!
Tue Feb 16, 2016 2:59 pm
http://www.loctite.com.au/3320_AUE_HTML ... 2626633729
Tue Feb 16, 2016 6:46 pm
That's what I use along with a couple more little tricks and I have NOT had the oil leaking issue the last 14 years on 4 different engines and 3 was modded.But than again I don't dog the shit out of mine most of the time.But good luck guys
Tue Feb 16, 2016 11:52 pm
I was changing mine every 20 hours or so. Had the sump side cut and bonded the case together. 50ish hours later and still holding good.
1648 gd hull flying in front of a stage 3 with fpr
Wed Feb 17, 2016 8:48 pm
Thu Feb 18, 2016 6:07 am
Thu Feb 18, 2016 1:22 pm
Thu Feb 18, 2016 2:56 pm
The horizontals suffer a lot from this. Try unbalanced cranks and flywheels; oh an that missing bolt!
Thu Feb 18, 2016 3:01 pm
Mon Feb 22, 2016 5:53 am
Speaking of Kawi charging systems. Can you add additional poles to the Stator to create more amperage?
Mon Feb 22, 2016 6:59 am
Mon Feb 22, 2016 7:08 am
Yeah, In all honesty With my older pre CDI engine, I haven't had an issue with the 20A stator.
Mon Feb 22, 2016 7:20 am
I never even ran a charging system on the briggs so whatever is on the kawi doesn't bother me at all.
Mon Feb 22, 2016 11:28 am
I got a 27pd. I wanna upgrade to a bigger engine. Is it a pain to swap from a 27hp to a 36hp engine? Does it bolt right up or what?
Grizzly 1448 w/ kawidrive
Sun Sep 04, 2016 9:00 pm
Tue Sep 06, 2016 5:04 am
Thanks! What shaft size? looks like there are 3 different sizes.
Wed Sep 07, 2016 10:18 pm
The one with 108mm long shaft.
Thu Sep 08, 2016 4:16 am
awesome! Do you run the DFI model or the carbed? It says the DFI is rated at 37hp. Im not sure if i would trust the DFI though being kind of new tech on these engines.
Thu Sep 08, 2016 10:48 am
The dfi has a 3600 rev limit, so not a good option.
Thu Sep 08, 2016 10:50 am
Good to know! Thanks for all the info man! Im gonna try and get it ordered in the next day or so. It looks like you can order them online. I guess they come w/o a muffler? So ill have to add that on. Is there anything ill need for the swap?
Thu Sep 08, 2016 10:56 am
Nope. The stock muffler is also super restrictive. You'll be better off making one or having someone make one for you. I think owen said he gained 400 rpms just gutting the stocker.
Thu Sep 08, 2016 11:09 am
Thu Sep 08, 2016 11:25 am
Thu Sep 08, 2016 12:52 pm
My case leaked at the oil ports in between the 2 halves since about 20 hours....I'm doing a hefty rebuild...no additional HPs...already a 5500 mag.
I'm going to do the new gasket along with sealant...maybe try the tack weld....
Let you know in a few months how it's holding up
Sent from my SAMSUNG-SM-G935A using Tapatalk
Thu Sep 15, 2016 8:55 pm
So did anybody ever end up putting tack welds to hold the case together? If so, how did it work?
Sun Jun 18, 2017 7:49 am
