It is currently Mon May 27, 2019 5:37 am
Reply to topic  [ 25 posts ]
 Torque specs/valve clearance specs
Post Torque specs/valve clearance specs
Can someone tell me right off hand the cylinder head and rocker arm bolts torqe specs for a 36pd also valve clearance specs? Thankx.
Sun Oct 24, 2010 8:57 pm
Post Re: Torque specs/valve clearance specs
Valve lash 0.004-0.006
Head Work:
Valve Cover 70 in. lbs (8 Nm)
Rocker Arm Stud 100 in. lbs (11 Nm)
Rocker Arm Lock Nut 70 in. lbs (8 Nm)
Cylinder Head 350 in. lbs (40 Nm)
Exhaust Manifold 180 in. lbs (20 Nm)
Intake Manifold 180 in. lbs (20 Nm)
Cylinder Shields 90 in. lbs (10 Nm)
Spark Plug 180 in. lbs (20 Nm)
Carb and Intake:
Carb to Manifold 90 in. lbs (10 Nm)
Carb Intake Elbow to Carb 90 in. lbs (10 Nm)
Air Cleaner Base to Carb 65 in. lbs (7 Nm)
Air Cleaner Support Bracket 65 in. lbs (7 Nm)
Air Cleaner Mounting 190 in. lbs (21 Nm)
Air Guide Mounting Screws 90 in. lbs (10 Nm)
Air Block Plate Mount Screws 90 in. lbs (10 Nm)
Flywheel and Fan:
Flywheel 150 ft. lbs (203 Nm)
Flywheel Fan Screws 90 in. lbs (10 Nm)
Ignition Armature 30 in. lbs (3 Nm)
Armature 35 in. lbs (4 Nm)
Rotating Screen Studs 125 in. lbs (14 Nm)
Rotating Screen Screws 100 in. lbs (11 Nm)
Alternator 35 in. lbs (4 Nm)
Voltage Regulator 90 in. lbs (10 Nm)
Engine:
Oil Pump to Crankcase Cover 90 in. lbs (10 Nm)
Oil Pickup to Pump 90 in. lbs (10 Nm)
Oil Pressure switch 80 in. lbs (9 Nm)
Oil Drain Plug 180 in. lbs (20 Nm)
Governor Control Bracket 200 in. lbs (23 Nm)
Governor Lever Nut 70 in. lbs (8 Nm)
Fuel Pump 45 in. lbs (5 Nm)
Connecting Rod 125 in. lbs (14 Nm)
Crankcase Cover 200 in. lbs (23 Nm)
Starter Motor 140 in. lbs (16 Nm)
Mon Oct 25, 2010 5:41 am
Gary, thanks. I'm gonna put da bookmark on dis.
If You Voted For Obama in '08, PHUCK YOU!
If you vote for him in 2012, I HOPE YOU DROWN IN A WARM POOL OF DIARRHEA!
Stage 2 GTR on da back of a Rick Aucoin battleship.
Mon Oct 25, 2010 9:02 am
Its garage art.
Mon Oct 25, 2010 4:21 pm
Deadbird8: link to those values? Does anyone have a link to a detailed manual with these specs and instructions for installing heads, porting and polishing intakes, decking heads as these procedures apply to vanguard engines? I can find generalized manuals but none have the depth and breath of information for which I am looking. Any help...links, publishers, online retainers, titles would be very helpful. Thanks in advance.
Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads. Currently: 17x46 Gator Tail with 35GTR and Hoyt's cam.
Please enter your boat data here: https://spreadsheets.google.com/viewform?hl=en&hl=en&authkey=CJCrk_oF&userstoinvite=ellidupre%40gmail.com&formkey=dHJVb0tOMWFUV1hZWDFTNFhZalZOUVE6MQ#gid=0
View all boat data here:https://spreadsheets.google.com/pub?hl=en&hl=en&key=0Al4r1k-hlfeIdHJVb0tOMWFUV1hZWDFTNFhZalZOUVE&output=html
Mon Oct 25, 2010 6:34 pm
Bump.... I need a manual. Help. Thanks
Tue Oct 26, 2010 8:06 am
Go to a briggs store and order one, or you can buy them online.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Tue Oct 26, 2010 8:18 am
x2 Briggs may even have a service manual in pdf format on their website. Kohler does. If not, order one... There's not gonna be any info on modifying the engine though, so nothing about porting then intake.
Tue Oct 26, 2010 8:41 am
I looked for a service manual. the documents that are in the basic engine and troubleshooting thread I made, has the manual, and the parts list. I couldn't find the service manual. BTW its hard searchign for the correct info on the Briggs site.. If someone finds the pdf of the service manual bookmark it. But I think hes just gonna have to buy it.
Bayou Surface Drive
337-351-0362
Tue Oct 26, 2010 9:22 am
If anyone knows it would be DB8... I've looked for some stuff on the briggs site before, like you said, its tough.
On another note, the kohler site is very easy to navigate. For those of you running kohlers, check it out. They have all the parts lists, owners manuals, and service manuals online...
Tue Oct 26, 2010 1:05 pm
Repair manual is orderable from briggs or others, I got mine from Jacks Small Engine. - it has a Briggs part number. I have not seen one on-line. Briggs doesn't have 'manuals' for modifying the engines (decking heads etc...)
If you are changing the heads then the manual is not gonna help you much except for torque sequence for the heads (which only shows 5 bolts instead of 6 in the diagram anyway). It doesn't go into step by step detail about pulling off the cowling etc... You would would need a 10mm, 12mm, 13mm, 14mm, Torx T40, and torque wrench. Take off the fan cage etc.., cowling, intake, valve covers,exhaust, then air baffle shields, and finally the 6 bolts for the head.
Porting the stock intake- I did a long post with pictures on the site that can't be named that gives a step by step. But they block that site here or I would post the link.
Fri Oct 29, 2010 1:59 pm
Marked!
Thu May 31, 2012 12:36 pm
Any one know the torque spec for the clutch bolt? (At least that's what I think it's called....the bolt that goes into the clutch and hold everything to the shaft) Thanks.
Fri Jul 12, 2013 7:31 am
Call peck and verify, but I want to say its around 70 ft lbs.
Fri Jul 12, 2013 7:47 am
Thank you, I will double check on it and post up what I find out.
Fri Jul 12, 2013 8:17 am
Think its more than that. Impact that sucker
Fri Jul 12, 2013 8:50 am
Sent an email to Micah at MB and he said 55 FT Lbs.
Mon Jul 15, 2013 2:11 pm
I thought this was still about a PD!? :lol:
Mon Jul 15, 2013 2:21 pm
Schriever retriever I live by custom corrugated sheet metal I work boats out back it in the book under Hardie Creel . I would like to have a chat with you as I live in Gray.
Sun Nov 08, 2015 3:15 pm
Hardie he posted that 5 years ago.
Sun Nov 08, 2015 5:40 pm
COULD some tell why ever one has to be so rude.
Sun Nov 08, 2015 7:52 pm
Can somekne tell your how to fuckin type and make sentences?
4Cody4 wrote:
Anybody with a duck count in their signature needs a stiff throat chop.
I'll deliver free of charge.
tracker grizzly 1448 w/ 1/8 bottom w/ custom grab bar, 18hp Dixie with trim
Talk SLOW i drive a dixie
Sun Nov 08, 2015 8:24 pm
If you would read, do some research and not be an ass, we might be a little nicer.
2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO
Mon Nov 09, 2015 2:58 am
Tough crowd up in this bitch! Hahaha
WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Sun Nov 29, 2015 6:43 pm
Always......always.
18' x 54" Uncle J Custom Center Console w/36 HP Prodrive - The FULL Story!
Backwater Performance Systems
Swamp Staff
WhoDat88 wrote:
Just think how much better MMT would be with out Dean as a member.
Mon Nov 30, 2015 1:43 pm
Users browsing this forum: No registered users and 24 guests
